avaarahoon
FPGA Manager for wireless-xorif design
I am trying to use FPGA Manager for wireless xorif-app design (Petalinux 2020.2) given here. I enabled FPGA Manager on petalinux-config and got this error:
ERROR: device-tree-xilinx-v2020.2+gitAUTOINC+f725aaecff-r0 do_compile: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:devicetree_do_compile(d)
0003:
File: '<petalinux-project>/components/yocto/layers/core/meta/classes/devicetree.bbclass', lineno: 131, function: devicetree_do_compile
0127: if not(os.path.isfile(dtspath)) or not(dts.endswith(".dts") or devicetree_source_is_overlay(dtspath)):
0128: continue # skip non-.dts files and non-overlay files
0129: except:
0130: continue # skip if can't determine if overlay
*** 0131: devicetree_compile(dtspath, includes, d)
0132:}
0133:
0134:devicetree_do_install() {
0135: for DTB_FILE in `ls *.dtb *.dtbo`; do
File: '<petalinux-project>/components/yocto/layers/core/meta/classes/devicetree.bbclass', lineno: 119, function: devicetree_compile
0115: dtcargs += ["-i", i]
0116: dtcargs += ["-o", "{0}.{1}".format(dtname, "dtbo" if isoverlay else "dtb")]
0117: dtcargs += ["-I", "dts", "-O", "dtb", "{0}.pp".format(dts)]
0118: bb.note("Running {0}".format(" ".join(dtcargs)))
*** 0119: subprocess.run(dtcargs, check = True, stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
0120:
0121:python devicetree_do_compile() {
0122: includes = expand_includes("DT_INCLUDE", d)
0123: listpath = d.getVar("DT_FILES_PATH")
File: '/tools/Xilinx/PetaLinux/2020.2/components/yocto/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.7/subprocess.py', lineno: 512, function: run
0508: raise
0509: retcode = process.poll()
0510: if check and retcode:
0511: raise CalledProcessError(retcode, process.args,
*** 0512: output=stdout, stderr=stderr)
0513: return CompletedProcess(process.args, retcode, stdout, stderr)
0514:
0515:
0516:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command '['dtc', '-@', '-@', '-p', '0x1000', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/hisilicon', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/actions', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/zte', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/sprd', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/xilinx', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/cavium', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/mediatek', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/exynos', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/marvell', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/realtek', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/lg', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/socionext', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/nvidia', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/scripts/dtc/include-prefixes', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/amd', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/altera', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/freescale', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/intel', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/qcom', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/arm', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/renesas', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/amlogic', '-i', '<petalinux-project>/project-spec/configs/../../components/plnx_workspace/device-tree/device-tree', '-i', '<petalinux-project>/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/rockchip', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/apm', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/allwinner', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/synaptics', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/ti', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/al', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/bitmain', '-i', '<petalinux-project>/build/tmp/work-shared/zynqmp-generic/kernel-source/arch/arm64/boot/dts/broadcom', '-o', 'system-top.dtb', '-I', 'dts', '-O', 'dtb', 'system-top.dts.pp']' returned non-zero exit status 1.
Subprocess output:
Error: <petalinux-project>/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0/system-user.dtsi:19.1-84 Label or path datapath_xxv_eth_subs_xxv_wrap_support_1588_2step_timer1588_subs_timer_1588_v2_0_0 not found
Error: <petalinux-project>/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0/system-user.dtsi:23.1-47 Label or path datapath_xxv_eth_subs_xxv_wrap_xxv_ethernet_0 not found
Error: <petalinux-project>/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0/system-user.dtsi:36.1-51 Label or path datapath_xxv_eth_subs_subs_2_arm_mm_dma_axi_dma_0 not found
FATAL ERROR: Syntax error parsing input tree
ERROR: Logfile of failure stored in: <petalinux-project>/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0/temp/log.do_compile.4292
ERROR: Task (<petalinux-project>/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
When I changed system-user.dtsi with the following content;
pcap {
       compatible = "xlnx,zynqmp-pcap-fpga";
       clocks = <&clk 41>;
fpga_full: fpga-full {
       compatible = "fpga-region";
       fpga-mgr = <&pcap>;
       #address-cells = <2>;
       #size-cells = <2>;
taken from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841847/Solution+ZynqMP+PL+Programming, and added this patch https://www.xilinx.com/support/answers/75856.html, error above disappeared but I get a kernel panic. Any suggestions?
xud
@avaarahoon
wireless-xorif hasn't been validated with FPGA Manager flow. If you use the makefile to build Petalinux images, do you see this problem?
The steps to use makefile are :
- create a new folder under wireless-xorif/xsa/, with name related to your design, for example, zcu102_om5_2020_1.
- Copy generated xsa file to this folder, and rename it to system.xsa
- Then you can cd to wireless-xorif/tree/master/scripts, and run make file command. For Example: make zcu111_om5_exs
 - This command run through all the necessary Petalinux flow, and build boot files.
If the boot files generate by "make" command works fine on your board, it means the problem might be related to FPGA Manager.
I will ask our Embedded Linux expert to follow up  this issue further
