FSBL Stuck at "Non authenticated Bitstream download to start now" ULTRA SCALE+
I am using ultra scale+ in my board & Peta Linux. While bootup it stuck with following message. There is no log after that.
"Non authenticated Bitstream download to start now".
Please suggest, how to debug further on this.
Escape character is '^]'.
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2   Oct  3 2018  -  12:00:52
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
Initializing DDR ECC
Address 0x0, Length 80000000, ECC initialized
Address 0x800000000, Length 80000000, ECC initialized
Processor Initialization Done
================= In Stage 2 ============
SD1 Boot Mode
SD: rc= 0
File name is 1:/BOOT0001.BIN
Multiboot Reg : 0x1
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x5
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x65216F
Data word offset: 0x65216F
Total Data word length: 0x65216F
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0xF580
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
Did you ever find out what the issue was here? I am getting a similar issue on my setup using QSPI for boot.
Not sure about the OP but for me this seemed to be an issue with the DDR4. I found that if I disabled the PS DDR4 it got past the bitstream load so I reviewed my DDR4 settings and found I had some timing parameters off.
hi  @evandavis @parmarankitin
could you tell me why my FSBL cann't  print "Non authenticated Bitstream download to start now" .
i use petalinux ,and config FPGA MANAGER to be yes .
Hi @parmarankitin
Did you use same tool version between FSBL, PMUFW, FPGA bit file and linux kernel ?
Best regards,
Voyager
Voyager
If you are using ZCU102 rev1.1 you should change DDR configuration of Zynq MPSoC. Required changes are given in the following link.
https://www.xilinx.com/support/answers/71961.html
