Visitor zawicki
Failed to compile tricube from UG1209
I have been following the embedded design tutorial (UG1209) using a ZCU102 board. I have been using the 2018.3 version of all tools (SDK, Vivado, and petalinux bsp).
For design example 2 (the tricube application), when I try to build petalinux (page 156 of UG1209 version 2018.3) I get the following output:
[INFO] building project
[INFO] generating Kconfig for project
[INFO] oldconfig project
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
[INFO] oldconfig rootfs
[INFO] generating petalinux-user-image.bb
INFO: bitbake petalinux-user-image
Loading cache: 100% |#######################################################################| Time: 0:00:00
Loaded 3461 entries from dependency cache.
Parsing recipes: 100% |#####################################################################| Time: 0:00:02
Parsing of 2570 .bb files complete (2528 cached, 42 parsed). 3462 targets, 136 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |##################################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |##########################################| Time: 0:00:26
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: tricube-1.0-r0 do_compile: Function failed: do_compile (log file is located at /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/temp/log.do_compile.8971)
ERROR: Logfile of failure stored in: /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/temp/log.do_compile.8971
Log data follows:
| DEBUG: Executing shell function do_compile
| /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot-native/usr/bin/aarch64-xilinx-linux/../../libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/7.3.0/ld: cannot find -lexpat
| /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot-native/usr/bin/aarch64-xilinx-linux/../../libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/7.3.0/ld: cannot find -lglapi
| /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot-native/usr/bin/aarch64-xilinx-linux/../../libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/7.3.0/ld: cannot find -lXxf86vm
| /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot-native/usr/bin/aarch64-xilinx-linux/../../libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/7.3.0/ld: cannot find -lGL
| collect2: error: ld returned 1 exit status
| WARNING: /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/temp/run.do_compile.8971:1 exit 1 from 'aarch64-xilinx-linux-g++ --sysroot=/usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0=/usr/src/debug/tricube/1.0-r0 -fdebug-prefix-map=/usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/recipe-sysroot= -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed tricube.cpp -lm -lpthread -ldl -lX11 -lxcb -lXau -lXdmcp -ldrm -lXfixes -lXext -lXdamage -lexpat -lglapi -lX11-xcb -lxcb-glx -lxcb-dri2 -lXxf86vm -lEGL -lGLESv2 -lGL -o tricube -I/usr/lib -L/usr/include'
| ERROR: Function failed: do_compile (log file is located at /usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/build/tmp/work/aarch64-xilinx-linux/tricube/1.0-r0/temp/log.do_compile.8971)
ERROR: Task (/usr/local/david.zawicki/Xilinx/edt/xilinx-zcu102-2018.3/project-spec/meta-user/recipes-apps/tricube/tricube.bb:do_compile) failed with exit code '1'
I believe I have followed the steps in the document correctly. How can I resolve this build issue?
Voyager
Voyager
Re: Failed to compile tricube from UG1209
Do you get the solution for this problem ?
I have the same issue.
Best regards
Visitor zawicki
I have been unable to find a solution.
