Observer nenghan
Failed to fwd host port to qemu
I booted up qemu and used the following command to expose the host port to qemu.
Petalinux-boot --qemu --kernel --qemu-args "-netdev user,id=n0,hostfwd=tcp::1534-:1534,hostfwd=tcp::5555-:22"
The qemu booted up and when I issue the ifconfig in qemu, I get the eth0 that was set to 10.0.2.15.
I was able to connect from the qemu to host via SSH (SSH admin@10.0.2.15)
However from the host, I can't connect to qemu through tcf-agent or SSH.
When I use xsdk and configure the Linux tcfagent with IP of localhost and port of 1534, it does not work
When I use terminal and attempt SSH to qemu (SSH localhost -p 5555) , it also can't connect.
Anyone have any inputs? Thanks
I'm using petalinux 2017.4 and project template of zynqmp.
Observer nenghan
Re: Failed to fwd host port to qemu
Correction, should be 10.0.2.2 which is the gateway
I was able to connect from the qemu to host via SSH (SSH admin@10.0.2.2)
Here is an old doc that might help others
