justinlh
Fatal Error: ff.h No such file or directory
I know this is probably a pretty general problem, with people having fatal error's missing a variety of files, but here we go. I am using petalinux 2013.10 xilinx sdk 2013.4.
This error occurs when building a new application project, hardware platform is my custom hardware(same error occurs on the default zc702 hardware platform), my OS platform is petalinux, and I set it to create a Zynq FSBL)
The file for help that I am currently using is ug980-petalinux-board-bringup.pdf (here)
I have verified that I have a symbolic link creating gmake from make.
I have sourced petalinux to set up my environment (though it would be nice if it would permanently set its environment variables), and verified that #echo $PETALINUX returns the needed path
achutha
Hi ,
Use XSDK standalone BSP to build fsbl and XSDK PetaLinux BSP for sync up hw and PetaLinux SDK sw.
Ram
achutha
Hi ,
Ram
audriusa
The file belongs to xilffs, Generic Fat File System library. In SDK, withing the used board support package (_bsp) project, click on system.mss, then on "modify BPS settings" and make sure that xilffs selected there between the libraries required. Regenerate BSP sources after that.
