Visitor toshibo
Fatal error: xenv_standalone.h: No such file or directory
Dear all,
I would like to create an Application Project based on the FS-BOOT (by PetaLogic) template.
As soon as I finish to create the Application, I obtain:
I already saw http://forums.xilinx.com/t5/Embedded-Linux/Petalinux-v12-12-auto-config-h-missing/m-p/302751#M5756 but it seems to not work for me.
I am using Vivado 2013.2, ubuntu 11.04, petalinux 2013.04. My board is a zedboard.
Here what I do:
1) From bash -> source setting.sh (with the patch mentioned here http://www.xilinx.com/support/answers/56388.htm ) to set the $PETALINUX path
2) I export my Vivado project in SDK
3) I add repository from $PETALINUX/hardware/edk_user_repository
4) I create an Application Project:
     -> Hardware Platform: zedboard
     -> OS platform            : Petalinux
5) I set the templates -> FS-BOOT
As soon as I click Finish, it starts  "Build of configuration Debug for project......." and then
Now, it does all by itself, so where is my mistake?
There is something wrong in the procedure?
Thanks a lot for your help.
Alberto
P.S.:
I also tried o create a Zynq FSBL project with XSDK stanalone BSP with "Zynq FSBL" template as explained in UG980 -> Board Bringup Guide but I obtain "fatal error: xil_io.h: No such file or directory". I did it just to follow exactly that guide but with no results...
Visitor toshibo
Re: Fatal error: xenv_standalone.h: No such file or directory
Dear all,
one step at time...
it seems it was a problem in my Ubuntu settings:
it tried to do gmake but I have "only" make.
If it happens again, try to do:
sudo ln -s /usr/bin/make /usr/bin/gmake
It should work.
Now, as you know, when you fix a problem, a even bigger problem happens.
Now I have two new errors:
../src/fs-boot.h:72:21: error: unknown type name 'u32'
../src/fs-boot.c:57:2: error: #error "Unknown architecture"
but I'll try to fix also them.
Any suggestion (or inspiration) is welcome.
