Fault segmentation error due to font type
Hello ,
I have a custom X11 program in which i am trying to use font type like :
XFontStruct *font;
main(){
font = XLoadQueryFont(dpy,win,gc,"-*-*-*-*-*-*-24-*-*-*-*-*-iso8859-*");
XSetFont(dpy,win,gc,font->fid);
XDrawString(dpy,win,gc, x1, y1, "HELLO", 5);
XFlush(dpy);
I used the font description using : xfontsel  in ubuntu machine. The program runs fine on the machine, but when i deploy it on the board i get segmentation fault errors.
I was able to point the errors to the use of font description instead of using default font style..
How do i include the different font styles on the board as well ??
Here is the boot image when i try to run my application with custom font style:
Tags (4)
Re: Fault segmentation error due to font type
Hi @vish.bh30,
Try with different font the fonts supported in native Ubuntu doesn't work on all embedded linux.
IMAGE_INSTALL_append = " \
    ttf-dejavu-sans \
    ttf-dejavu-sans-mono \
    ttf-dejavu-sans-condensed \
    ttf-dejavu-serif \
    ttf-dejavu-serif-condensed \
    ttf-dejavu-common \
Sandeep
Hi @sandeepg
Which file do i need to make these changes to?
is it :
<petalinux_project>\project-spec\meta-plnx-generated\conf\layer.conf
or
<petalinux_project>\\project-spec\meta-user\conf\layer.conf
Hi @sandeepg
So i tried the fix you suggested in file :
<petalinux_project>\project-spec\meta-user\conf\layer.conf
I got the following errors when i tried to generate a build :
Based on the fix you provided, i also tried adding some other type of fonts as well , but this is what i got during build :
error :
Is there any change done to the dejavu fonts in term of how they are downloaded ? Can we install it to embedded system build without downloading them . I see various fonts in my Linux machine , can't we use those ?
Vishal
