Participant mberemand
File Format not Recognized when packaging user app
I'm encountering an unhelpful error when trying to build my rootfs to include a very basic pre-compiled app. The bitbake recipe is as follows:
# This file is the Demo recipe.
SUMMARY = "Demo"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://Demo.HEX \
       file://Demo2.out \
       file://test.bin \
       file://Demo1.out \
S = "${WORKDIR}"
do_install() {
         install -d ${D}/home/root/Demo
         install -m 0755 ${S}/*.out ${D}/home/root/Demo
         install -m 0644 ${S}/Demo.HEX ${D}/home/root/Demo
         install -m 0644 ${S}/test.bin ${D}/home/root/Demo
This recipe is incredibly simple so I'm not sure why it results in this error:
arm-xilinx-linux-gnueabi-objcopy:/home/common/peta_proj_2017.2_secure/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/Demo/1.0-r0/package/home/root/Demo/Demo1.out: File format not recognized
 I tried removing the .out files from the recipe, but then I got an equally confusing error:
WARNING: Demo-1.0-r0 do_package: QA Issue: Demo: Files/directories were installed but not shipped in any package:
  /home
  /home/root
  /home/root/Demo
  /home/root/Demo/Demo.HEX
  /home/root/Demo/test.bin
I have no idea what could possibly be wrong, seeing as a very similar recipe works just fine:
# This file is the openssl-libs recipe.
SUMMARY = "openssl-libs"
LICENSE = "MIT"
SRC_URI = "file://libcrypto.so.1.1 \
           file://libssl.so.1.1 \
S = "${WORKDIR}"
do_install() {
	     install -d ${D}/usr/lib
	     install -m 0755 ${S}/*.1.1 ${D}/usr/lib
Re: File Format not Recognized when packaging user app
So my understanding is that bitbake is trying to be helpful by stripping unneeded symbols from the binary, but runs into this problem because of it. In order to override this default behavior, I had to add
INHIBIT_PACKAGE_STRIP = 1
to the recipe.
https://stackoverflow.com/questions/53765087/file-format-not-recognized-when-building-petalinux-app
First of all, don't use uppercase characters for recipe name(bb file)
demo recipe builds several packages as default.
demo-dbg, demo-staticdev, demo-dev, demo-doc, demo-locale, demo
You have to describe each installed file belongs to which package like this
PN variable means demo, demo package includes all installed files
SUMMARY = "Demo"
LICENSE = "MIT"
       file://Demo2.out \
       file://test.bin \
       file://Demo1.out \
S = "${WORKDIR}"
FILES_${PN} = "/home/root/Demo/*"
do_install() {
I recreated the app under an all-lowercase name and added the FILES_${PN} assignment but I'm still getting the same "File format not recognized" error on the .out files. Why is bitbake concerned with the files' formats in the first place? I'm not compiling anything, just placing them in the rootfs.
to the recipe.
