GPIO mapping of Zynq on zedboard
From the page:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842398/Linux+GPIO+Driver
> root@xilinx-zc702-2017_2:~# cd /sys/class/gpio/
> root@xilinx-zc702-2017_2:~# ls
  export    gpiochip906    unexport
> root@xilinx-zc702-2017_2:/sys/class/gpio# cat gpiochip906/label
  zynq_gpio
  The above line indicates that gpio 0th pin starts from 906 and ends at 1023 (GPIO has total 118 pins for Zynq)
I got to know that the GPIO start index is 906 for the ZYNQ of my zedboard.
But I cannot map the GPIO number(such 906+10=916) to the pin name and number on the chip zynq.
is there any doc to guide me about the mapping?
Best Regards,
Ardeal
Hi @ardealliang,
GPIO906 is the name of the first GPIO of the controller. So if you want to use the driver from the user space the document mentioned by you will help you.
"The only question is I don't know which pin on the board is set when I run echo 1 > gpio916/value."--
gpio916 is the chip name of the MIO10. If you are exporting this gpio then you can set the direction and write a value to the pin.
Let us consider the MIO7 which is LD9( refer the user guide).
From the wiki page we can say that the chip name of the MIO7 is gpio913(906+7). So now we will try to set the direction and write a value to the GPIO
root@My_proj_en_ktimer:/sys/class/gpio# cd /sys/class/gpio/
root@My_proj_en_ktimer:/sys/class/gpio# ls
export gpio916 gpiochip906 unexport
you can see the list of exported as well.
Now give the command echo 913 > /sys/class/gpio/export
export gpio913 gpio916 gpiochip906 unexport
Next - root@My_proj_en_ktimer:/sys/class/gpio# cat /sys/class/gpio/gpio913/direction
   in --> this is the expected output
So if you want to change the direction you can make it out.
root@My_proj_en_ktimer:/sys/class/gpio# echo out > /sys/class/gpio/gpio913/direction
root@My_proj_en_ktimer:/sys/class/gpio# echo 1 > /sys/class/gpio/gpio913/value(This will turn on the LD9 )
root@My_proj_en_ktimer:/sys/class/gpio# echo 0 > /sys/class/gpio/gpio913/value(This will turn off the LD9 )
Try this for the MIO7 and you understand what is happening.
Refer
http://zedboard.org/sites/default/files/documentations/ZedBoard_HW_UG_v2_2.pdf
https://www.xilinx.com/support/documentation/university/XUP%20Boards/XUPZedBoard/documentation/ZedBoard_RevC.1_Schematic_130129.pdf
Best Regards
Abhinay PS
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Hi @ardealliang,
What is the error you are getting once you export it using echo 916 > /sys/class/gpio/export?
Kranthi
Best Regards
Kranthi
Hi @gudishak,
No error when I run:
this is the reason why I want to know the mapping between gpio number and pin name or pin number.
Could you please tell me the doc or link about the mapping?
Best Regards,
Ardeal
Hi @gudishak,
I have zedboard, and I would like to control JE pins on the board.
The following picture is captured from zedboard schematic, which is the pins I would like to control:
Could you please tell me what GPIO number should be exported on ARM to control those upper pins?
Best Regards,
Ardeal
Is there anyone could help to answer my question?
Many thanks!
Is there anyone could answer my question?
Thanks!
Thanks!
Ardeal
Hi @ardealliang,
Refer
Best Regards
Abhinay PS
Best Regards
Abhinay PS
@abhinayp
Your solution works!
many thanks!
