nookfu
Garbage output on UART when booting Petalinux (custom hdf-file)
Hi there,
I am trying to implement a Vivado project on ZynQ US+ MPSoC zcu102. After generateing the bitstream and exporting hardware, I followed the implementation flow described in UG1144 to generate Petalinux boot image. Unfortunately, after booting with SD-card, I am only receiving garbage output from Zynq over UART. On the other hand, if I create petalinux-build without a custom HDF, the UART connection works without issues and I am able to boot. I am guessing it is some kind of buad-rate issue between my Vivado Project and Petalinux config but I am so far unable to fix the issue.
I suspect that my hardware configuration in Vivado might be wrong, because I might have misunderstood the following requirement: In UG1144 it is mentioned that to configure Zynq MPSoC to boot Linux, an external memory controller and UART is required (p19). Does this mean I have to add and configure specific memory controller and UART IPs in my Vivado project?  I thought these blocks only need to be configured inside the Zynq PS IP Block.
I would appreciate any hints regarding my issue. Thanks!
Versions:
Vivado 2018.2
Petalinux 2018.2
zcu102 BSP 2018.2
glena
The PS REF CLK on the ZCU102 is 33.33 MHz in hardware, make sure it is also set to that in Vivado.
glena
The memory and UART controllers referred to in UG1144 are for the PS IP block.
nookfu
I see. It seems something else is causing the issue then.
Is there perhaps something I have to consider when setting PS_REF_Clk? It is set to 30MHz.
Clock configuration for UART is 100MHz IOPLL with 115200 Baud Rate.
glena
