Observer alexlear
Getting I2C EEPROM driver to work in Petalinux
I'm having some difficulty getting the EEPROM driver working in Petalinux v2013.10.
I have two I2C connections to a Zynq PS running at 400kHz.  ps7_i2c_1 is the EEPROM connection.  The device I am using is a MicroChip 24LC128.  All three chip address inputs are grounded for a 0x50 address.  I have editted the system.dts file as follows to add the EEPROM:
ps7_i2c_0: ps7-i2c@e0004000 {
        bus-id = <0>;
        clocks = <&clkc 38>;
        compatible = "xlnx,ps7-i2c-1.00.a";
        i2c-clk = <400000>;
        interrupt-parent = <&ps7_scugic_0>;
        interrupts = <0 25 4>;
        reg = <0xe0004000 0x1000>;
        xlnx,has-interrupt = <0x0>;
ps7_i2c_1: ps7-i2c@e0005000 {
        bus-id = <1>;
        clocks = <&clkc 39>;
        i2c-clk = <400000>;
        interrupts = <0 48 4>;
        reg = <0xe0005000 0x1000>;
        xlnx,i2c-reset = "<Select>";
        eeprom@50 {
                compatible = "at24,24c128";
                reg = <0x50>;
I've also configured the kernel with ->Device Drivers->Misc Devices->EEPROM Support->I2C EEPROM from most vendors
When I boot petalinux, I see these entries for I2C in the terminal output:
i2c /dev entries driver
xi2cps e0004000.ps7-i2c: 400 kHz mmio e0004000 irq 57
xi2cps e0005000.ps7-i2c: 400 kHz mmio e0005000 irq 80
I don't see the device "file" that I expect at: /sys/bus/i2c/devices/1-0050/eeprom
/dev/ lists both i2c-0 and i2c-1 but I'd like to use the EEPROM driver.
I haven't used EEPROM from petalinux in this way before so maybe I am missing something.  Any help is appreciated!
Thanks!
Alex
Observer alexlear
Re: Getting I2C EEPROM driver to work in Petalinux
To follow up on my own post....
After verifying the configuration/drivers and rebuilding the kernel and rootfs it appears to now be working.  The above method is correct.  In researching this I also found that you can also instantiate the eeprom device from userspace with:
echo eeprom 0x50 > /sys/bus/i2c/devices/i2c-1/new_device
- Alex
