How can I modify kernel source code in meta-xilinx kernel?
Other kernel recipes in the Yocto Project store the sources in a folder according to tmp/work/<ARCH>/linux/<version>/git/.
With a kernel.bbappend file I could add new files to the source code, e.g. a custom device tree source file:
SRC_URI += "file://git/arch/arm64/boot/dts/custom_device_tree.dts"
In the Xilinx Layer the kernel sources seem to be stored in the tmp/work-shared directory. I found a symlink to this directory in tmp/work:
tmp/work/<ARCH>/linux-xlnx/<version>/linux-<MACHINE>-standard-build/source
However, adding files to this path via SRC_URI seems to have no effect (no device tree source files in the resulting tmp/work-shared directory for the kernel source):
SRC_URI += "file://linux-<MACHINE>-standard-build/source/arch/arm64/boot/dts/custom_device_tree.dts"
So I wonder what the common way is to add/modify sources to the linux-xlnx kernel via Yocto.
Any hints are highly appreciated.
I found a solution now by modifying the S variable:
I took linux-qoriq_4.1.bb from the freescale layer as base and copied following lines into a *.bbappend for linux-xlnx:
KSRC ?= ""
S = '${@base_conditional("KSRC", "", "${WORKDIR}/git", "${KSRC}", d)}'
The resulting kernel source is then placed like I have posted in my head post and thus can be modfied via SRC_URI easiliy.
KSRC ?= ""
