wqvist
How do I incorporate fsbl_hooks.c from embeddedsw into my Petalinux project?
This thread says to create a patch for fsbl_hooks.c and place it in project-spec/meta-user/recipe-bsp/fsbl/files, but the build log doesn't say anyting about embeddedsw or fsbl_hooks. Plus I can't get my fsbl to work as intended. (I'm trying to set a MAC address.)
How can I patch something that doesn't exist?
I'm using Petalinux 2018.3.
desulmelionel
Hey did you ever figure out the issue?
wqvist
If I remember correctly, turned out fsbl_hooks was never my actual problem. Sorry I can't be more specific, it was a long time ago.
aravindb
HI @wqvist
1.First try to create a fsbl patch after doing your modifications with same branch 2018.3
2. copy your patch to <plnx-proj-root>/project-spec/meta-user/recipes-bsp/fsbl/ directory
3. petalinux-build
It should work, if not works please share your changes what you want to modify , i will create a patch & verify then share with you.
Thanks & regards
Aravind
desulmelionel
Hey,
Thanks, however i am using 2019.2
