swinchen
How do you determine which pins correspond to a devicetree group on the ZynqMP?
How do you determine which pins are associated with i2c0_3_grp, as show below?  The mapping is not explicitly written out in the devicetree binding documentation.
pinctrl_i2c0_default: i2c0-default {
		mux {
			groups = "i2c0_3_grp";
			function = "i2c0";
		conf {
			bias-pull-up;
			slew-rate = <SLEW_RATE_SLOW>;
			io-standard = <IO_STANDARD_LVCMOS18>;
Sam
ottob
This was quite frustrating for me as well.. But the information you want is in
/sys/kernel/debug/pinctrl/ff180000.pinctrl
for instance, check out the pingroups file
group: mdio1_0_grp
pin 50 (MIO50)
pin 51 (MIO51)
group: mdio1_1_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: mdio2_0_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: mdio3_0_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: qspi0_0_grp
pin 0 (MIO0)
pin 1 (MIO1)
pin 2 (MIO2)
pin 3 (MIO3)
pin 4 (MIO4)
pin 8 (MIO8)
pin 9 (MIO9)
pin 10 (MIO10)
pin 11 (MIO11)
pin 12 (MIO12)
etc
Have a great weekend !
/Otto
trigger
Voyager
Voyager
	DEFINE_ZYNQ_PINCTRL_GRP(i2c0_3),
Hi @swinchen,
I'm not an expert but:
If you take a look in linux-xlnx/drivers/pinctrl/pinctrl-zynq.c (line 302):
static const unsigned int i2c0_3_pins[] = {22, 23};
After that we can see a macro (DEFINE_ZYNQ_PINCTRL_GRP @line 391)
#define DEFINE_ZYNQ_PINCTRL_GRP(nm) \
		.name = #nm "_grp", \
		.pins = nm ## _pins, \
		.npins = ARRAY_SIZE(nm ## _pins), \
So when the macro is called with
the "_grp" is added to the name.
At the end we have i2c0_3_grp -->  {22, 23};
I'm not sure if it's really clear so feel free to ask if you more info about that :)
Good luck,
Cheers.
Trigger
swinchen
Hi , Trigger.
Thanks for the response.
We are using the ZynqMP (Ultrascale+ SoC), not the Zynq-7000.  The pinctrl driver is linux-xlnx/drivers/pinctrl/pinctrl-zynqmp.c which behaves much differently than the Zynq-7000 pinctrl.  It appears as though the pinctrl driver for the ZynqMP queries the PMU firmware to determine groups and pins.
Sam
trigger
Voyager
Voyager
Hi Swinchen,
Sorry, my bad :-( I'm not able to read the title correctly ...
Cheers,
Trigger
ottob
group: mdio1_0_grp
pin 50 (MIO50)
pin 51 (MIO51)
group: mdio1_1_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: mdio2_0_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: mdio3_0_grp
pin 76 (MIO76)
pin 77 (MIO77)
group: qspi0_0_grp
pin 0 (MIO0)
pin 1 (MIO1)
pin 2 (MIO2)
pin 3 (MIO3)
pin 4 (MIO4)
pin 8 (MIO8)
pin 9 (MIO9)
pin 10 (MIO10)
pin 11 (MIO11)
pin 12 (MIO12)
etc
/Otto
swinchen
How do you enable that debug interface? is that a dyndbg thing?
swinchen
mount -t debugfs none /sys/kernel/debug/
This did it.  Thanks!
