How test design " PL Ethernet through SFP"
I have zc706 board with Vivado&SDK&Petalinux 2018.3 on ubuntu 2016.04.
I'm going to design PL Ethernet through SFP using XAPP1082 document and also follow the instruction of the following link:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841633/Zynq+PL+Ethernet
After writing bitstream, export hardware and lunch SDK I follow the instruction of link 2.4 PL Ethernet section with little different as I used *.hdf file to make the image with Petalinux.
after all, I copy boot.bin and image.ub into SD card ( fat32 format) and plug it into my board (adjust jumper for sd card). Also, run minicom on my Linux (I used sfp to rj45 converter and use cat5 cable). Then, use Root, Root for login and password that show on minicom screen. After this, I have no clue what should I do for the next step. Is there any advice or document that I can use to know how to test this kind of design?
It would be great if someone gives me some advice in this case?
Bests,
Hi @adnan86
Try setting up the IP addresses at host and target end, and as a basic sanity test, try to ping and see if that works
Best Regards
Shabbir
did you start from a ref design ? e.g.
https://www.xilinx.com/support/documentation/application_notes/xapp1305-ps-pl-based-ethernet-solution.pdf
