daguiar
How-to: Disable BOOTP Broadcast
Is there a way to disable the BOOTP broadcast step (shown below) within U-boot? It takes a fair amount of time, and I know that I want to boot straight from the stored image on an SD card.
ethernet@e000b000 Waiting for PHY auto negotiation to complete....... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
I'm working with a zc702 board, and I need to disable this option in the image that is stored onto the SD card rather than perform any interactive u-boot commands.
I have tried a few things, including disabling ethernet drivers in the options shown in petalinux-config -c u-boot, and I have looked at posts like this one, but I have yet to find anything that works.
jfranz-argo
Were you able to resolve this issue? I'm trying to do the same thing -- disable BOOTP broadcasts on boot and use a static IP.
tgharbi2020
Did you resolve the problem?
jfranz-argo
Hello tgharbi2020,
I was able to resolve this by disabling DHCP using petalinux-config:
-> Subsystem AUTO Hardware Settings -> Ethernet Settings:
