How to add application binary to petalinux? is it should be a .elf file?
 I am following the UG1144 page50 to include prebuilt applications to petalinux.
1.Create an application with the following command.
    $ petalinux-create -t apps --template install --name myapp --enable
2Change to the newly created application directory.
   $ cd <plnx-proj-root>/project-spec/meta-user/recipes-apps/myapp/files/
3. Remove existing myapp app and copy the prebuilt myapp.
   $ rm myapp
   $ cp <path-to-prebuilt-app> .
In my case the prebuilt myapp is a .elf file from the SDK (using a standalone application project) .
After I copy the .elf to the location mentioned on the 3rd steps and execute "petalinux-build" commond, a error show up:
ERROR: Nothing RPROVIDES 'helloworldSanJose' (but /home/petalinux_project/armcore_project0606/for_test_lib/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb RDEPENDS on or otherwise requires it)
Then I checked the helloworldSnajose.bb  file.
# This file is the helloworldSnajose recipe.
SUMMARY = "Simple helloworldSnajose application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://helloworldSnajose \
S = "${WORKDIR}"
do_install() {
	     install -d ${D}/${bindir}
	     install -m 0755 ${S}/helloworldSnajose ${D}/${bindir}
 I didn't find some hint from that.
But when I build a template $ petalinux-create -t apps --template install --name myapp --enable, notice the binary file has no .elf.
Now I am confuse with which kind of binary file should I put in the petalinux?
Re: How to add application binary to petalinux? is it should be a .elf file?
Hi mathmaxsean
first of all, I think that you shoul compile the application for the linux enviroment.
Standalon and linux are two different worlds.
Hope that this shoul be helpful for you.
Bye
Hello @mathmaxsean,
What I can see is the following:
Look at how you did Snaj? And the error says:
Maybe because you install helloworldSnaJose and SanJose.
**Also make sure the .elf file is compiled with the same compiler as your kernel uses.
回复: How to add application binary to petalinux? is it should be a .elf file?
Please try as the picture shown
You will ahve to edit the bb file to properly build the new app.
LICENSE = "MIT"
SRC_URI = "file://helloworldSnajose.elf \
S = "${WORKDIR}"
INSANE_SKIP_${PN} = "arch"
do_install() {
install -d ${D}/lib/firmware
install -m 0755 ${S}/helloworldSnajose.elf ${D}/lib/firmware
FILES_${PN} = "/lib/firmware/helloworldSnajose.elf"
Do change this as your .bb file.
regards...
Hi @mathmaxsean ,
I'm doing same thing with Vivado/SDK/Petalinux 2018.2.
First thing is first. If you want to have a Petalinux application, you need to create it again in Xilinx SDK as Linux application.
Bare Metal needs BSP project to work properly and it is completly different.
After recreating your project, you can build it in SDK and If you can build it without errors, you can go next step.
By using SDK, you can also debug your Linux by using Hardware Debug(I found this feature wonderful.)
Whenever you are sure, everything is fine, then I copy-paste to my source files into related folder in Petalinux apps.(<plnx-proj-root>/project-spec/meta-user/recipes-apps/myapp/files/)
It means, instead of copying executable, I'm copying sources.
Then, petalinux-build builds also our application.
If you want to build only your project and do not want to wait too long time, then you can use:
petalinux-build -c my_app -x cleanall
Saban
<--- If reply is helpful, please feel free to give Kudos, and close if it answers your question --->
