maju42
How to build a kernel module using petalinux?
Hi, all
I want to build the kernel module from here: https://github.com/nvdla/sw/tree/master/kmd. The instruction given on how to configure and compile this directory is:
make KDIR=<path_to_Linux_source> ARCH=arm64 CROSS_COMPILE=<path_to_toolchain>
I want to build this using petalinux without creating any additional module. So what should be the <path_to_Linux_source> , <path_to_toolchain> in this case?
watari
Hi @maju42
FYI.
=> Download suitable linux kernel same as what you use by petalinux.
<path_to_toolchain>
=> Your cross compiler toolchain path
ex. <your installed SDK directory>/aarch64/lin/aarch64-linux/bin
Best regards,
watari
Hi @maju42
FYI.
<path_to_toolchain>
Best regards,
