Newbie sunguk-bin
How to build the kernel as 32-bit for ZCU102
I have an pre-developed 32-bit kernel and kernel module.
Xilinx linux kernel only support 64bit configuration for ultrascale SOC (ZCU102); xilinx_zynqmp_defconfig..
There are the way to build the kernel as 32-bit ?
Otherwise, is there an way to execute 32-bit kernel driver on 64-bit kernel without modification (type size ...)?
Re: How to build the kernel as 32-bit for ZCU102
check this ARs
https://www.xilinx.com/support/answers/66636.html
Thanks and Regards
Balkrishan
Newbie sunguk-bin
Thanks quick reply. But my interesting thing is making kernel to 32-bit and cpu core works aarch32. I'm already running 32-bit application on 64-bit kernel. I hope to run 32-bit application on 32-bit kernel. But there is no corresponding defconfig.
no i think its not possible Zynq only support 64 bit Kernel. You can run 32-bit or 64-bit application
Thanks and Regards
Balkrishan
