How to check the location and allocated size of home/root folder
Hi.
Sorry for the elementary question.
Using the Zynq(Z-7045) board and Petalinux 2016.2,
I put a file in the home/root directory.
But I don't know where these files are in the filesystem.
root@TEST:~# ls -l
-rw-r--r-- 1 root root 395005 Feb 12 20:52 0.gz
-rw-r--r-- 1 root root 16 Jan 1 1970 test.txt
root@TEST:~# cat /etc/fstab
# stock fstab - you probably want to override this with a machine specific one
/dev/root / auto defaults 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
tmpfs /run tmpfs mode=0755,nodev,nosuid,strictatime 0 0
tmpfs /var/volatile tmpfs defaults 0 0
# uncomment this if your device has a SD/MMC/Transflash slot
#/dev/mmcblk0p1 /media/card auto defaults,sync,noauto 0 0
root@TEST:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 376468 0 376468 0% /dev
tmpfs 386072 20 386052 0% /run
tmpfs 386072 16 386056 0% /var/volatile
Where is home/root located in the file system?
Also, please tell me how much file size I can put in home/root?
Thank you.
Re: How to check the location and allocated size of home/root folder
HI @s3s_elec
Please just use this below commands to find the location of the file.
locate file_name
find -name file_name
For knowing your file size, use this below command.
ls -sh file_name
du -sh home/root/
Note: By defulat locate command will not be presnet in petalinux rootfs, you need enable & build it.
Thanks & regards
Araivnd
Thank you for your reply, Araivnd.
Sorry for the confusing question.
The find command shows that the file is in ./home/root .
The "Used" column value for all three items displayed as a result of the df command is less than 0.gz.
Are the files (0.gz, test.txt) elsewhere than these three?
root@TEST:~# df
If so, why isn't that area displayed by the df command?
Thank you.
Mentor
Mentor
Hi @s3s_elec
You mean evan if linux mount /dev/root as / and there are some files on /, you can't recognize used file size on result of df, right ?
If yes, would you share the following result ?
df -k -T
Best regards,
Thank you for your reply, watari.
Sorry for my lack of understanding. Your guess is correct.
I ran the command.
root@TEST:~# df -k -T
Filesystem Type 1K-blocks Used Available Use% Mounted on
devtmpfs devtmpfs 376468 0 376468 0% /dev
tmpfs tmpfs 386072 20 386052 0% /run
tmpfs tmpfs 386072 16 386056 0% /var/volatile
Thank you.
I haven't changed Petalinux's config on mounting the region,
and I haven't run the mount command since boot.
Is /home/root not mounted anywhere?
Mentor
Mentor
Hi @s3s_elec
Would you share boot log to investigate the root cause, if possible ?
Best regards,
Please check the boot log.
I have attached the file.
Thank you.
Mentor
Mentor
Hi @s3s_elec
According to your log file, I can't find rootfs and it seems that you don't define rootfs.
Where do you describe your rootfs ?
Also how do you describe it ?
Best regards,
As you say, I have not set up rootfs.
The settings are left at default.
("base-system-default" is selected(*) for "Filesystem Packages")
I only run "petalinux-config -c rootfs" before building to add my apps.
I just want to make space for large files (hundreds of MB).
Also, I do not know the capacity limit of /home/root/ now.
I'm sorry I don't know the basics.
I study about rootfs.
Thank you.
