How to compress kernel image in petalinux filtimage
My image.ub has increased too much from 2018.3 to 2019.2, when I investigated the reason I found that kernel image is uncompressed in latest petalinux.
Can anyone please give me a solution to the problem.
Thanks ,
Kayas Ahmed
Re: How to compress kernel image in petalinux filtimage
I didn't mean manually, I wanted a solution in Petalinux config,
Anyways I have solved the issue by generating Fitimage manually using the deploy build image of Petalinux.
Kayas Ahmed
OK, can you mark this as solved then please
