How to disable ethernet at petalinux boot
I found AR#59073 which seems to describe what I wish to accomplish (but for petalinux 2013.10): do not start the ethernet controller at boot-up. However in petalinux 2015.2.1 it seems impossible to disable init-ifupdown.
I don't want to use DHCP to get an IP-address and I also don't want all my boards to start up with the same fixed IP-address. I want to set the IP-address at the end of boot-up with a script of my own. The latter is easy, but how to do the first?
Kind regards,
Maarten
Re: How to disable ethernet at petalinux boot
Argh, and if I manually set CONFIG_ROOTFS_PACKAGES_INIT_IFUPDOWN=n then I also don't get the loopback interface.
Is it really so extraordinary to have several Zynq's running linux in a larger setup?
And does Xilinx really expect all users to either use DHCP or rebuild the rootfs for every machine?
have you fould a solution for diable ethernet at boot time?
Not really. I usually set an invalid IP address now, but it's not quite the same as having the interface down at startup.
See also http://stackoverflow.com/questions/10456044/what-is-a-good-invalid-ip-address-to-use-for-unit-tests
petalinux-config:
Subsystem AUTO HW Settings:
Ethernet Settings -->
Set it to manual
This may help you.
Debraj
This did not change anything for me. The networking configuration step still takes place on boot.
