Visitor cthil
How to enable i2c subsystem in PetaLinux U-Boot
I'm using Vivado/PetaLinux 2015.2 to build the complete Linux system, including FSBL and U-Boot. How do I enable the I2C subsystem in U-Boot to access, for example, an EEPROM?
I want to modify U-Boot to read some parameters out of the factory-programmed EEPROM if they are not set in the U-Boot environment.
Christophe
Visitor rocco.brandi
Re: How to enable i2c subsystem in PetaLinux U-Boot
Hi Christophe,
I am trying to do the same thing. Have you found out how to do it?
Rocco
just to let you know,
I have managed to enable I2C in U-boot.
I have noticed that zynq_zc70x.h is replaced by platform-top.h
this file is stored in <$PETALINUX-PROJECT-DIRECTORY>/subsystems/linux/configs/u-boot.
so I have added  the following settings from file <$U-BOOT-SOURCE-DIRECTORY>/include/configs/zynq-common.h to file  <$PETALINUX-PROJECT-DIRECTORY>/subsystems/linux/configs/u-boot/platform-top.h:
#define CONFIG_SYS_I2C_ZYNQ
/* I2C */
#if defined(CONFIG_SYS_I2C_ZYNQ)
# define CONFIG_CMD_I2C
# define CONFIG_SYS_I2C
# define CONFIG_SYS_I2C_ZYNQ_SPEED  100000
# define CONFIG_SYS_I2C_ZYNQ_SLAVE  0
#endif
and it worked! Of course to have acces to the I2C buses, the bitsream file must be loaded before u-boot.
I hope it could help someone else.
Best Regards,
Rocco
