Scholar watari
How to execute qemu with 2018-2-zcu-release.tar.xz (Segmentation fault/core dump)
Hi all
I'd like to deeply know the boot sequence with MPSoC by qemu.
Then I proceed with it as below.
1. download 2018.2-zcu102-release.tar.xz from http://www.wiki.xilinx.com/Zynq+2018.2+Release
2. extract tar.xz file and prepare three files from image.ub by dumpimage command.
$ dumpimage -i image -T flat_dt -p 0 uImage
$ dumpimage -i image -T flat_dt -p 1 system.dtb
$ dumpimage -i image -T flat_dt -p 2 uramdisk.img.gz
Extracted system.dtb is same as original system.dtb
3. Do qemu with the following options.
$ qemu-system-aarch64 -M arm-generic-fdt -serial mon:stdio -serial /dev/null -display none -device loader,addr=0xfd1a0104,data=0x8000000e,data-len=4 -device loader,file=./bl31.elf,cpu-num=0 -device loader,file=./u-boot.elf -dtb ./system.dtb
However, after step 3, I got "Segmentation fault (core dump)".
Where did I go wrong ?
Would you help me ?
I just know the boot sequence by qemu, especially I'd like to know the behavior of device tree blob by qemu.
Re: How to execute qemu with 2018-2-zcu-release.tar.xz (Segmentation fault/core dump)
Hi Watari,
The images that are in the release folder will allow you to boot your ZCU102 board. But these do not have the qemu dtb's that you will need for booting qemu as well. For this, I would suggest to download the ZCU102 bsp from here
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
When you extract this bsp, you will see all the pre-built images along with the qemu dtbs in the pre-built/linux/images folder.
What is your requirement exactly? Do you just want to run the pre-built images on qemu?
As a starting point, if you have a petalinux project for a zcu102 bsp, you can load it on qemu using the command petalinux-boot --qemu --kernel.
You can see the qemu instances which get invoked when you use this command. Following this you can use the command line options to run the images on qemu.
Hi Watari,
For ZynqUltrascale+ you will need 2 instances, one for arm and another for pmu firmware. You can follow the example we have on our wiki here. The qemu dtb needs to be passed as well.
http://www.wiki.xilinx.com/QEMU%20-%20Zynq%20UltraScalePlus
For additional examples and details you can also check out the Qemu user guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1169-xilinx-qemu.pdf
Scholar watari
Hi @jovitac
Thank you for your help.
I'm trying your suggestion. But I have not resolved yet.
I will reply it irrespective of whther success or not.
Thank you.
Scholar watari
Hi @jovitac
I have a question.
Q)
Even if I use "2018.2-zcu-release.tar.xz" which is downloaded from Xilinx, I need to build linux-kernel and/or u-boot by PetaLinux. Is it correct understanding ?
If yes, what purpose does this "2018.2-zcu-release.tar.xz" ?
I'm trying it without compiling PetaLinux. But I can't resolve it yet.
Hi Watari,
Scholar watari
Hi @jovitac
Thank you for your kindly explanation.
The route cause is my mis-understanding about 2018-2-zcu-release.tar.xz .
I thought that I could run qemu with the extracted files.
However it's misunderstanding. I have to prepare some files by petalinux.
OK. I understand it.
I will try it.
BTW, if possible, would you modify the content to add some suggestion or nortification on this wiki page ?
Thank you.
