Participant diy_a
How to generate bitstream file(download.bit) from Xilinx SDK 2016.4 ?
I have been trying to generate bitstream file (download.bit) from Program the FPGA window box with the bootloader file.
I cant find any select option to add the bootloader file(.elf) in the software configuration. How to add it ?
BMM/MMI File box is greyed out . how to enable it ?
How to create a Zynq Boot image with bootloader(fsbl.elf),download.bit(bitstream file) and u-boot.elf in Xilinx SDK 2016.4 ?
Hereby I attached the "Program the FPGA" window box i have got.
Help with this...!
Thanks in advance...
Re: How to generate bitstream file(download.bit) from Xilinx SDK 2016.4 ?
you can refer complete tutorial from SDK design hub
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0015-sdk-hub.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug940-vivado-tutorial-embedded-design.pdf#nameddest=xBuildingAZynq7000ProcessorDesign
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug898-vivado-embedded-design.pdf
Thanks and Regards
Balkrishan
Participant diy_a
Re: How to add bitstream file with bootloader file(fsbl.elf) to PROGRAM THE FPGA in Xilinx SDK 2016.4 ?
I have already generated the bitstream file. But i would like to know how to add the bootloader file ( fsbl.elf ) along with the bit-stream file to program the FPGA.
As there is no SELECT option to add the boot loader file in the software configuration Menu.
NOTE : I am using Xilinx SDK 2016.4 Version
Participant diy_a
       There is no option to add bootloader file. Have a look at the image i have attached in the post. There is no SELECT or ADD option in software configuration menu to add bootloader file( fsbl.elf) in the PROGRAM THE FPGA window box .
Have a look at the 1st image i have got from Xilinx forum. There it shows the bootloader file in the software configuration menu.
Now see the 2nd image i have got from my SDK.  There is no option to add the bootloader file in PROGRAM THE FPGA window box under software configuration menu.
thank you.
