How to get netserver or netperf into petalinux 2017.1 ?
I want to test the ethernet ports on zc706 and iperf3 has not given benchmark results. How can i get netserver into petalinux ? Does yocto provide netserver or netperf package? Thanks in advance.
Voyager
Voyager
Re: How to get netserver or netperf into petalinux 2017.1 ?
Hey @jenny_august13,
How's that?
How can i get netserver into petalinux?
Probably easiest via the meta-networking recipes.
There seems to be an import from OpenEmbedded for netperf available for yocto.
Best,
Herbert
-------------- Yes, I do this for fun!
It is showing an error that runtime target "netperf" is unbuildable, removing... missing or unbuildable dependancy chain and build has failed.
Now i installed netperf into my linux system and then trying to build as previously there is not netperf installed in the system. But facing the same problem.
Ah.. do i need licence for this to use it in petalinux?
 Nothing RPROVIDES 'netperf' (but /home/projects/peta2017.1-zcu102/zc706/ptlnzc706/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb RDEPENDS on or otherwise requires it)
ERROR: netperf was skipped: because it has a restricted license not whitelisted in LICENSE_FLAGS_WHITELIST
Ah, it is non-commercial licence.
Observer marode
For reference: you can add to meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append = "netperf"
However, a few months ago netperf has moved to gihub and the FTP server has been shut down.
To fix this, replace the recipe in <petalinux_inst_dir>/components/yocto/source/aarch64/layers/meta-networking/recipes-support/netperf/ with the netperf_git.bb from
https://github.com/openembedded/meta-openembedded/blob/master/meta-networking/recipes-support/netperf/
for the license issue see
Cannot build because it has a restricted license not whitelisted.
(This was working with PetaLinux 2017.4)
