add_engineering
How to indicate two SATA lanes on ZynqMP in device tree
This is what should be inserted in the device tree for a SATA lane (for the SERDES/PHY config)
&sata {
    phys = <&lane2 PHY_TYPE_SATA 0 3 150000000>;
However, when using 2 SATA lanes, what should be included in the device tree then? The examples list
the use of one PHY per device, while the ZynqMP has a SATA controller that has two channels, hence, 2 PHY's are required.
How should I enter this in the device tree?
Thanks!
hpoetzl
Voyager
Voyager
Hey @add_engineering
I would say like this:
&sata0 {
    phys = <&lane2 PHY_TYPE_SATA 0 2 150000000>;
&sata1 { phys = <&lane3 PHY_TYPE_SATA 1 3 150000000>;
Note that you need to adjust the lane and controller numbers accordingly.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
add_engineering
There is only one SATA entry in the generated device tree. It is an entry for the controller.
hpoetzl
Voyager
Voyager
Sorry, I don't have access to a ZynqMP, but maybe this works:
&sata {
    phys = <&lane2 PHY_TYPE_SATA 0 2 150000000>, <&lane3 PHY_TYPE_SATA 1 3 150000000>;
Again, double check the parameters to both entries.
Hope this helps,
Herbert
add_engineering
Hi Herbert,
No I already tried that. The "driver" should iterate through this list but it doesn't.
Kind Regards
add_engineering
The "trick" is: you do not have to specify the phy anymore. Make sure you use the driver for SATA-controller that is more recent than the one in 2017.2!  The driver in 2017.2 does not handle the use 2 SATA ports correctly!
