How to install petalinux on Digilent Atlys Spartan6 LX45 FPGA
I downloaded
Digilent-atlys-v2013.04-final.bsp
from Downloads page of Xilinx, however after
tar zxf Digilent-atlys-v2013.04-final.bsp
only hardware folder was created, no "petalinux" dir, and no "settings.sh" script.
what steps are required to install petalinux on this board?
I am using Xilinx ISE on Ubuntu 12.10 and I create projects and program them on FPGA successfully.
To use this BSP you need to install Petalinux.
Please follow the documentation as shown here. http://www.xilinx.com/publications/products/petalinux/petalinux-installation-guide.pdf
--HS
The procedure is to use petalinux-install-bsp. This is documented in page 6 of this document
Check the attached snapshot for example
there is no such tool, I downloaded
I did tar this and there is no
petalinux-install-bsp script. Should I download another bsp and call instalation script pointing to my file bsp?
Which version of petalinux are you using?
--HS
I don't have any petalinux! As I said I just downloaded and tar bsp file as described on Xilinx site
and here \http://www.wiki.xilinx.com/PetaLinux+Installation
I did steps 1,2,3,4 and I did
(note this is not Digilent-atlys-v2013.04-final-full.bsp  there is no such file to download)
and next it is said to do source settings or someone else said to run petalinux command but I have no petalinux folder or program installed.
do I have to install petalinux other way and then install bsp?
--HS
OK, I have missed the petalinux archive and downloaded only BSP files.
"click on the appropriate links to download the 'PetaLinux XX.YY installation archive' and all required BSPs."
thank you
I'm trying to load a prebuilt kernel image and I have an issue, I'm  usin Ise Design tools 13.2 and Petalinux SDK 13.04, could I have a problem with ther versions??
LEVEL 3 BOOT:
Configuring the FPGA...
FPGA configuration completed.
Downloading and booting Linux Kernel from RAM memory, this may take a few minutes.
Launching XMD for file download and boot.
This may take a few minutes, depending on the size of your image.
WARNING: es_AR:es is not supported as a language.  Using usenglish.
ERROR: Unable to download the image
Done..
Connect hyperterminal or kermit at 115200 baud.
thank you
thank you
Login using root/root as the username and password
