Visitor abuchowicz
How to patch axi-vcu.tcl in Petalinux?
I have a design in Vivado/Petalinux 2017.4.Porting to the newer version is currently impossible.
Unfortunately DTG generates incorrect register addresses for VCU as described here: https://forums.xilinx.com/t5/Embedded-Linux/vcu-problem/td-p/897664
One of users mentions patching the axi_vcu.tcl file. However, I can't find it neither in my project nor in Petalinux. How can I patch this file, so that the correct DTS will be generated?
TIA & Regards,
Andrzej
Scholar wzab
Re: How to patch axi-vcu.tcl in Petalinux?
The answer record: https://www.xilinx.com/support/answers/70296.html decribes the procedure to patch the device tree generator.
It is worth to look into the patches:
https://www.xilinx.com/Attachment/0001-Update-the-ddr4-driver-if-it-has-more-memory-ranges.patch
https://www.xilinx.com/Attachment/0001-Update-the-logic-to-fix-the-main-memory-node.patch
Probably the patch shown in  https://forums.xilinx.com/t5/Embedded-Linux/vcu-problem/m-p/907222/highlight/true#M30078 may be applied in a similar manner (see the "Solution" section in https://www.xilinx.com/support/answers/70296.html . It describes how and where modify the device-tree-generation_%.bbappend file.).
It is also possible to generate the patch, changing the 2017.4 version of axi_vcu.tcl into the 2018.3 version:
git clone https://github.com/Xilinx/device-tree-xlnx.git
cd device-tree-xlnx
git diff xilinx-v2017.4 xilinx-v2018.3 -- axi_vcu/data/axi_vcu.tcl > ../0001-axi-vcu-2017.4-2018.3.patch
So generated patch, however, contains additional sections, not included in the patch published in the referenced post (I attach the generated patch below).
diff --git a/axi_vcu/data/axi_vcu.tcl b/axi_vcu/data/axi_vcu.tcl
index b9f0e66..a2aef94 100644
--- a/axi_vcu/data/axi_vcu.tcl
+++ b/axi_vcu/data/axi_vcu.tcl
@@ -24,10 +24,19 @@ proc generate {drv_handle} {
     # Generate properties required for vcu node
     set node [gen_peripheral_nodes $drv_handle]
+    if {$node == 0} {
+           return
     hsi::utils::add_new_dts_param "${node}" "#address-cells" 2 int
     hsi::utils::add_new_dts_param "${node}" "#size-cells" 2 int
-    set tab "\n\t\t\t\t"
-    set reg "0x0 0xa0040000 0x0 0x1000>,$tab<0x0 0xa0041000 0x0 0x1000"
+    hsi::utils::add_new_dts_param "${node}" "#clock-cells" 1 int
+    set vcu_ip [get_cells -hier $drv_handle]
+    set baseaddr [get_baseaddr $vcu_ip no_prefix]
+    set slcr_offset 0x40000
+    set logicore_offset 0x41000
+    set vcu_slcr_reg [format %08x [expr 0x$baseaddr + $slcr_offset]]
+    set logicore_reg [format %08x [expr 0x$baseaddr + $logicore_offset]]
+    set reg "0x0 0x$vcu_slcr_reg 0x0 0x1000>, <0x0 0x$logicore_reg 0x0 0x1000"
     set_drv_prop $drv_handle reg $reg int
     set intr_val [get_property CONFIG.interrupts $drv_handle]
     set intr_parent [get_property CONFIG.interrupt-parent $drv_handle]
@@ -48,24 +57,51 @@ proc generate {drv_handle} {
     # Generate child encoder
     set ver [get_ipdetails $drv_handle "ver"]
-    set encoder_node [add_or_get_dt_node -l "encoder" -n "al5e@a0000000" -p $node]
+    set encoder_node [add_or_get_dt_node -l "encoder" -n "al5e@$baseaddr" -p $node]
     set encoder_comp "al,al5e-${ver}"
     set encoder_comp [append encoder_comp " al,al5e"]
     hsi::utils::add_new_dts_param "${encoder_node}" "compatible" $encoder_comp stringlist
-    set encoder_reg "0x0 0xa0000000 0x0 0x10000"
+    set encoder_reg "0x0 0x$baseaddr 0x0 0x10000"
     hsi::utils::add_new_dts_param "${encoder_node}" "reg" $encoder_reg int
     hsi::utils::add_new_dts_param "${encoder_node}" "interrupts" $intr_val int
     hsi::utils::add_new_dts_param "${encoder_node}" "interrupt-parent" $intr_parent reference
     # Fenerate child decoder
-    set decoder_node [add_or_get_dt_node -l "decoder" -n "al5d@a0020000" -p $node]
+    set decoder_offset 0x20000
+    set decoder_reg [format %08x [expr 0x$baseaddr + $decoder_offset]]
+    set decoder_node [add_or_get_dt_node -l "decoder" -n "al5d@$decoder_reg" -p $node]
     set decoder_comp "al,al5d-${ver}"
     set decoder_comp [append decoder_comp " al,al5d"]
     hsi::utils::add_new_dts_param "${decoder_node}" "compatible" $decoder_comp stringlist
-    set decoder_reg "0x0 0xa0020000 0x0 0x10000"
+    set decoder_reg "0x0 0x$decoder_reg 0x0 0x10000"
     hsi::utils::add_new_dts_param "${decoder_node}" "reg" $decoder_reg int
     hsi::utils::add_new_dts_param "${decoder_node}" "interrupts" $intr_val int
     hsi::utils::add_new_dts_param "${decoder_node}" "interrupt-parent" $intr_parent reference
+    set clknames "pll_ref aclk vcu_core_enc vcu_core_dec vcu_mcu_enc vcu_mcu_dec"
+    overwrite_clknames $clknames $drv_handle
+    set ip [get_cells -hier $drv_handle]
+    set pins [get_pins -of_objects [get_nets -of_objects [get_pins -of_objects $ip "vcu_resetn"]]]
+           foreach pin $pins {
+                set sink_periph [::hsi::get_cells -of_objects $pin]
+                set sink_ip [get_property IP_NAME $sink_periph]
+                if {[string match -nocase $sink_ip "xlslice"]} {
+                        set gpio [get_property CONFIG.DIN_FROM $sink_periph]
+                        set pins [get_pins -of_objects [get_nets -of_objects [get_pins -of_objects $sink_periph "Din"]]]
+                                set periph [::hsi::get_cells -of_objects $pin]
+                                set ip [get_property IP_NAME $periph]
+                                set proc_type [get_sw_proc_prop IP_NAME]
+                                if {[string match -nocase $proc_type "psu_cortexa53"] } {
+                                        if {[string match -nocase $ip "zynq_ultra_ps_e"]} {
+                                                set gpio [expr $gpio + 78]
+                                                hsi::utils::add_new_dts_param "$node" "reset-gpios" "gpio $gpio 0" reference
+                                if {[string match -nocase $ip "axi_gpio"]} {
+                                         hsi::utils::add_new_dts_param "$node" "reset-gpios" "$periph $gpio 0 1" reference
 proc get_ipdetails {drv_handle arg} {
I don't know if so generated DT will be compatible with the 2017.4 version of the IP core.
Wojtek
Visitor abuchowicz
Dear Wojtek,
I have applied the patch to the device tree generator created as you described in your latest post. However the following error occured during the compilation
| invalid command name "overwrite_clknames"
| ERROR: [Hsi 55-1545] Problem running tcl command ::sw_axi_vcu::generate : invalid command name "overwrite_clknames"
|     while executing
| "overwrite_clknames $clknames $drv_handle"
|     (procedure "::sw_axi_vcu::generate" line 66)
|     invoked from within
| "::sw_axi_vcu::generate U_PROC_vcu_system_vcu_0"
I've modified the patch by replacing the line containing the command 'overwrite_clknames' with an empty line. The modified patch is listed below
+    if {$node == 0} {
+           return
The project, after applying the above patch, compiles with no errors.
I have successfully modprobe'd the xlnx_vcu driver, but the following error was reported:
[  127.860167] xilinx-vcu 80140000.vcu: failed to set logicoreIP refclk rate
The patch partially solved the problem: vcu register addresses have the correct values now, but vcu is still not properly initialized.
Andrzej
Scholar wzab
The lacking "overwrite_clknames" procedure is very simple ( https://github.com/Xilinx/device-tree-xlnx/blob/b7466bbeeede15ec72143e3c3466e067589821a1/device_tree/data/common_proc.tcl#L1636 ):
proc overwrite_clknames {clknames drv_handle} {
        set_drv_prop $drv_handle "clock-names" $clknames stringlist
Maybe it is sufficient to add it?
I attach the patch that should do that.
Wojtek
Visitor abuchowicz
The patch solved the 'invalid command name "overwrite_clknames"' problem but the 'xilinx-vcu 80140000.vcu: failed to set logicoreIP refclk rate' error message still is displayed.
I've tried to encode the YUV sequence using the 'AL_Encoder.exe' application (from petalinux-2017.4). Unfortunately the app hangs up the entire system after encoding first 15 frames of the input sequence.
Andrzej
