Observer _kumar
How to reduce xilinx uboot and Linux boot time
Hi, I have a project with kintex 7 fpga, microblaze processor.
The processor is ported with xilinx uboot v2014 and Linux v3.12.
Currently my system takes 50 secs to not and get application start.
Need help to reduce this time.
Re: How to reduce xilinx uboot and Linux boot time
Hi Kumar,
For 'Reduce Boot Time' , will get set of Presentations from ELC (Embedded Linux Conference) 2014, 2015.
Check in elinux.org for ELC Presentations
Main Idea is, remove set  of Peripherals from u-boot code
& make silent of set of I/O Devices which are not needed at the Boot time.
For Ex: Your Device is booting with  SD card , you can remove  Ethernet Support, QSPI Support from Boot Code.
Thanks & Regards
Satish.G
G Satish Kumar
Voyager
Voyager
Hi @_kumar,
Could you share bootlog with timestamp?
Cheers,
Trigger
Observer _kumar
I have attached my boot log, which contains the boot prints from board power on to linux command line.
Thanks!
Voyager
Voyager
Hi ,
You should take a look to :
[    0.794562] RPC: Registered udp transport module.
[    0.794678] RPC: Registered tcp transport module.
[    0.794800] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.918263] Skipping unavailable RESET gpio -2 (reset)
[    7.945828] futex hash table entries: 16 (order: -4, 448 bytes)
7 seconds for do what?
You are talking about 50 sec but :
[   12.521659] Freeing unused kernel memory: 2212K (c0421000 - c064a000)
Starting rcS...
Last point, if you want to lauch your application you have to add init script to start your app :)
Cheers,
Trigger
Observer _kumar
Yes, you pointed it rightly. Any suggestions on how to do this?
I said my total system boot time is 50 secs, right from power on to linux shell (#) [This step includes FSBL, U-Boot, Linux]
-Thanks!
Voyager
Voyager
Hi ,
To reduce boot time:
- You can disable waiting time in u-boot (3/5 sec).
- Check DTS to find something about this strange reset : https://github.com/mqmaker/linux/blob/master/arch/microblaze/kernel/reset.c
And maybe update kernel -> Linux-3.15.0 is a little bit old isn't it ?
Cheers,
Trigger
