How to use the custom user module in root petalinux 2014.4
I have precompiled my linux module like the following pdf and it is built when I build the kernel. Once I boot the kernel I am having trouble understanding how to use the .ko driver that was prebuilt in the kernel.
The .ko driver is no where in the root directory but was built and installed to the rootfs.
lsmod shows nothing but I think that is correct.
[root@localhost mydma]# find ../../../ -name "xfifo*"
../../../build/linux/rootfs/modules/xfifo_dma
../../../build/linux/rootfs/modules/xfifo_dma/xfifo_dma.o
../../../build/linux/rootfs/modules/xfifo_dma/xfifo_dma.mod.c
../../../build/linux/rootfs/modules/xfifo_dma/xfifo_dma.c
../../../build/linux/rootfs/modules/xfifo_dma/xfifo_dma.mod.o
../../../build/linux/rootfs/modules/xfifo_dma/xfifo_dma.ko
../../../build/linux/rootfs/modules/xfifo_dma/.tmp_versions/xfifo_dma.mod
../../../build/linux/rootfs/targetroot/lib/modules/3.17.0-xilinx/extra/xfifo_dma.ko
../../../components/modules/xfifo_dma
../../../components/modules/xfifo_dma/xfifo_dma.c
root@Xilinx-ZC706-2014_4:/# find / -name "*xfifo*"
The procedure to include pre-built modules into PetaLinux root file system is mentioned on page 63 of the following guide
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1144-petalinux-tools-reference-guide.pdf
did you use the same method?
The below link provides details on how to add kernel modules to Petalinux root file system.
http://www.xilinx.com/support/answers/55997.html
Achutha
I am. I just got my modules to load on the board and I am not sure what I did. I am using the bsp with my hw description imported to the project.
Thanks for the response!
Kevin
