Visitor hfeng2016
I2C access lost after reprogram PL
I have a Linux kernel 4.0.0 build by petalinux 2015.4 running on Microzed(ZYNQ7020), with an AXI_I2C controller in the FPGA PL, the I2C access from linux works fine after fresh reboot. But if I reprogram the PL by dump the same bit stream to devcfg from Linux, I lost the I2C access. I also have AXI_GPIO within the same PL, the GPIO access works fine after reprogram the PL.
Anybody have experience on this issue?
Tags (2)
Voyager
Voyager
Re: I2C access lost after reprogram PL
Hey @hfeng2016,
... if I reprogram the PL by dump the same bit stream to devcfg from Linux ...
Double check that it is actually the same bit stream you are sending to /dev/xdevcfg as was loaded during Linux boot. Also make sure to re-initialize the AXI IIC driver (e.g. unload and reload the kernel module) to accommodate for the now reset PL hardware.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Visitor hfeng2016
Hi Herbert,
I'm pretty sure it's the same bit stream.
How do I reinitialize the I2C driver? apparently lsmod doesn't return anything under linux-xlnx.
Henry
Voyager
Voyager
Hey Henry,
You probably need to build the kernel driver as module to do so.
Make sure that the kernel is built with module support and that /proc is mounted.
Hope this helps,
Herbert
