Observer manikumar086
I2C bus not detecting in U-Boot
Need help on I2C bus detection in U-Boot.
My Hardware details : K7 FPGA with Microblaze with basic interfaces (ddr, uart, flash) and 2 I2C buses
U-Boot version : 2014.01
Able to compile and run U-Boot on microblaze but while trying to access I2C bus facing an issue as below and MicroBlaze is getting hanged :
"Error, wrong i2c adapter 0 max 0 possible"
above line is printing from "i2c_set_bus_num()" of "drivers/i2c/i2c_core.c".
Any suggestions why is this issue occuring and how to fix it?
-Thanks
Attached the xparameters.h, microblaze-generic.h, System.map file which has entries of I2C details too.
Re: I2C bus not detecting in U-Boot
Did you enable the I2C in the kernel configuration?
Please refer to details in the link.
http://www.wiki.xilinx.com/Linux+I2C+Driver
Achutha
Thank you for your reply.
The link provided by you is for Linux but requirement is to access I2C from U-Boot.
-Thanks
Scholar norman_wong
No experience with the Microblze. A guess. From looking at the u-boot and linux source, u-boot does not have i2c adapter code for the Microblaze i2c. On the linux side, it is i2c-xiix.c. You will have to port the linux version or the bare metal code from the SDK.
