Installing netperf and netserver in ZCU102 eval board.
Hello ,  I am performing PS-MIO ethernet test. For that in need netperf and netserver to be installed. For this currently I am trying this :
 In <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf , adding the following lines
IMAGE_INSTALL_append = " netperf"
IMAGE_INSTALL_append = " netserver"
But its throwing error ,
 Please help me to include netserver and netperf.
Thanks and Regards
Raj kumar
Hi @raj_jha_01
For netperf the error you are getting in Petalinux is related to licensing:
netperf was skipped: because it has a restricted license not whitelisted in LICENSE_FLAGS_WHITELIST
If you take a look to the license of the recipe in the OpenEmbedded layer/recipe index, you will see that it has a non-commercial license flag which prevents building it ooo. This question was already addressed in the following forum post.
For netserver, I cannot find the recipe in the OpenEmbedded index, so not sure which package is this one.
Ibai
Hi @raj_jha_01
As @ibaie rightly mentioned please follow the existing thread. BTW mentioning netperf recipe alone builds both netperf and netserver
Shabbir
