Visitor giovanig
Is it possible to run FreeRTOS on the R5 using the RPMsg interface (ZCU102)?
I am able to run bare metal code on the R5 processor from the Linux running on the A53 in the ZCU102 platform.
I tried to run the FreeRTOS hello world demo using the same RPMsg procedure (the remoteproc filesystem interface), but I got a runtime error:
[ 6013.718289] remoteproc remoteproc0: powering up ff9a0100.zynqmp_r5_rproc
[ 6013.725404] remoteproc remoteproc0: Booting fw image freertos_hello_world.elf, size 535624
[ 6013.733640] remoteproc remoteproc0: bad phdr da 0x100000 mem 0x27bc0
[ 6013.739928] remoteproc remoteproc0: Failed to load program segments: -22
[ 6013.746664] remoteproc remoteproc0: Boot failed: -22
My question is: is it possible to run FreeRTOS on tha R5 from Linux running on A53 via remoteproc or any other way?
Best
Giovani
Visitor giovanig
Re: Is it possible to run FreeRTOS on the R5 using the RPMsg interface (ZCU102)?
I was able to solve the problem.
I changed the psu_r5_ddr_0_MEM_0 in the ldscript.ld file to point to a physical memory location that is not used by Linux (reserved in device tree file). Base Address used was 0x3ED00000 and size was 0x00040000.
Another question now:
How to interrupt FreeRTOS from Linux? For instance, to inform that a new data should be read from a shared memory location. Using RPMsg, we can just use rpmsg_send or write to /dev/rpmsg0.
