Is there any commands that can limit/manage the bandwidth
Hello support team,
I just installed the 'petalinux' but I cannot find out how to limit/manage the network bandwidth by command. Are there any commands that can do the job like 'netem' on Ubuntu?
Thank you
The 'netem' seems to be part of the "tc" traffic control tool, which itself is part of "iproute2" package. (https://www.man7.org/linux/man-pages/man8/tc-netem.8.html)
You can enable iproute2 and tc commands as follows:
petalinux-config -c rootfs
   Filesystem Packages ---> base ---> iproute2 ---> iproute2-tc
You will likely also need to enable some options in the kernel, as per https://wiki.linuxfoundation.org/networking/netem. Under petalinux you would use 'petalinux-config -c kernel' for this. You can build these into the kernel, or as modules (which you then need to load with "modprobe").
Thank rfs613, this works for me.
