Is there rzsz on petalinux for serial file transfer
I hope to transfer files via serial port.
My petalinux is 2018.2 installed on ubuntu16.
I download lrzsz-1.12.20.tar.gz and unzip under /home/liwenz/tmp/rzsz, but I don't know ./configure.
I tried the next command.
./configure CC=arm-linux-gnueabihf-gcc --host=arm-unknown-linux --prefix=/home/liwenz/tmp/rzsz
and then ./configure CC=arm-linux-gnueabihf-gcc  --prefix=/home/liwenz/tmp/rzsz
It show as follow:
configure: warning: CC=arm-linux-gnueabihf-gcc: invalid host type
loading cache ./config.cache
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
then I make and make install
I have not got the result.
Any idea?
Re: Is there rzsz on petalinux for serial file transfer
Hi @liwenz,
This package is already available in Yocto http://cgit.openembedded.org/openembedded-core/tree/meta/recipes-bsp/lrzsz/lrzsz_0.12.20.bb?h=rocko just include this in your petalinux project
In <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
# Add this at end
IMAGE_INSTALL += "\
    lrzsz \
Sandeep
Thanks. Why not add as a line,like that
IMAGE_INSTALL += "    lrzsz     "
Thanks for your reply.But I have not got it.
Do you mean I need down load it?
I only add in petalinuxbsp.conf, but it does not work
root@gpio:/bin# lrz
-sh: lrz: command not found
root@gpio:/bin# lsz
-sh: lsz: command not found
root@gpio:/bin# rz
-sh: rz: command not found
root@gpio:/bin# sz
-sh: sz: command not found
root@gpio:/bin#
Observer adefan
How to do this ? where to put *.bb and files in the petalinux project ?
Observer adefan
I found it myself.  it is tue that "This package is already available in Yocto "
don't need to download anything. Just refer to ug1144 page 80.
Open
<plnx-proj-root>/project-spec/meta-user/recipes-core/images/petalinux-image.bbappend and add the following line:IMAGE_INSTALL_append = " lrzsz"
Run
petalinux-config -c rootfs
Select “user packages -->”
Select “network-->”
Select “lrzsz”
Enable it, save and exit
