Observer kevin.jesse
Issue programming bitstream through petalinux but not through vivado
I am not getting any visible errors while programming the bitstream with petalinux sdk it just hangs.
[root@localhost Xilinx-ZC706-2014.4]# petalinux-boot --jtag --prebuilt 3INFO: Append dtb - /home/kevinjesse/Projects/Xilinx-ZC706-2014.4/pre-built/linux/images/system.dtb and other options to boot zImage
INFO: Configuring the FPGA...
INFO: XMD commands is shown as follows.
fpga -f "/home/kevinjesse/Projects/Xilinx-ZC706-2014.4/pre-built/linux/implementation/download.bit"
after 2
INFO: Downloading bitstream to the target.
When I put the bitstream on the board with vivado and then use petalinux-boot --jtag --u-boot and petalinux-boot --jtag --kernel I am able to use the board.
How can I figure out what is going wrong with petalinux? When I cancel the programming I get the following message:
cat: /tmp/tmp.v1IfHcYl6M: No such file or directory
ERROR: FPGA configuration failed.
Kevin
Re: Issue programming bitstream through petalinux but not through vivado
Fixed. Local machine programming issue.
