Kernel Panic and SD boot issue
hello ,
I am trying to load a "hello world" app (install or default template) created using petalinux viz SD boot in ultrazed mpsoc board.
1. when i generated the boot package, it loaded the flashed linux image and not from SD card, on further investigation found that this is a issue with petalinux and applied it's given fix (https://www.xilinx.com/support/answers/69780.html)
but once i did this i am getting kernel panic :
Xilinx Zynq MP First Stage Boot Loader
Release 2017.3   Feb  2 2018  -  17:09:48
NOTICE:  ATF running on XCZU3EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):f9b244b
NOTICE:  BL31: Built : 11:38:21, Feb  2 2018
U-Boot 2017.01 (Feb 02 2018 - 16:42:21 +0530) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  2 GiB
ERROR: usb dr_mode not found
at /home/vishal/myprj/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/drivers/usb/common/common.c:32/usb_get_dr_mode()
EL Level:       EL2
Chip ID:        xczu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1 (SD)
zynqmp_qspi_ofdata_to_platdata: CLK 124999999
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for myprj
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded
Device: sdhci@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 200000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
reading image.ub
13409532 bytes read in 898 ms (14.2 MiB/s)
   Using 'conf@2' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d8
     Data Size:    13376000 Bytes = 12.8 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   628acd2e0a34598c9bca20e254286ed3bb007d48
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10cc1bd0
     Data Size:    32227 Bytes = 31.5 KiB
     Hash algo:    sha1
     Hash value:   d1e5b5683b11e32f22122934066ab2331f42adbe
   Booting using the fdt blob at 0x10cc1bd0
   Loading Kernel Image ... OK
   Loading Device Tree to 0000000007ff5000, end 0000000007fffde2 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.3 (vishal@vishal-VirtualBox) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Fri Feb 2 16:53:14 IST 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc06ff7b000 s48152 r8192 d29672 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517120
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1789200K/2097152K available (9084K kernel code, 582K rwdata, 2816K rodata, 512K init, 395K bss, 45808K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008960000   (  9088 KB)
[    0.000000]     .rodata : 0xffffff8008960000 - 0xffffff8008c30000   (  2880 KB)
[    0.000000]       .init : 0xffffff8008c30000 - 0xffffff8008cb0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008cb0000 - 0xffffff8008d41a00   (   583 KB)
[    0.000000]        .bss : 0xffffff8008d41a00 - 0xffffff8008da4634   (   396 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008255] Console: colour dummy device 80x25
[    0.012515] console [tty0] enabled
[    0.015880] bootconsole [cdns0] disabled
[    0.019790] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.019807] pid_max: default: 32768 minimum: 301
[    0.019925] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019936] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020588] ASID allocator initialised with 65536 entries
[    0.021139] zynqmp_plat_init Power management API v0.3
[    0.021222] EFI services will not be available.
[    0.021597] Detected VIPT I-cache on CPU1
[    0.021628] CPU1: Booted secondary processor [410fd034]
[    0.021914] Detected VIPT I-cache on CPU2
[    0.021932] CPU2: Booted secondary processor [410fd034]
[    0.022210] Detected VIPT I-cache on CPU3
[    0.022228] CPU3: Booted secondary processor [410fd034]
[    0.022267] Brought up 4 CPUs
[    0.022301] SMP: Total of 4 processors activated.
[    0.022310] CPU features: detected feature: 32-bit EL0 Support
[    0.022322] CPU: All CPU(s) started at EL2
[    0.022338] alternatives: patching kernel code
[    0.023108] devtmpfs: initialized
[    0.027744] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.033973] xor: measuring software checksum speed
[    0.071894]    8regs     :  2111.000 MB/sec
[    0.111925]    8regs_prefetch:  1882.000 MB/sec
[    0.151956]    32regs    :  2594.000 MB/sec
[    0.191987]    32regs_prefetch:  2183.000 MB/sec
[    0.192001] xor: using function: 32regs (2594.000 MB/sec)
[    0.192102] pinctrl core: initialized pinctrl subsystem
[    0.192825] NET: Registered protocol family 16
[    0.214092] cpuidle: using governor menu
[    0.214315] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.214494] vdso: 2 pages (1 code @ ffffff8008967000, 1 data @ ffffff8008cb4000)
[    0.214521] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.215137] DMA: preallocated 256 KiB pool for atomic allocations
[    0.225707] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.226584] ARM CCI_400_r1 PMU driver probed
[    0.229970] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.250392] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.316291] raid6: int64x1  gen()   373 MB/s
[    0.384210] raid6: int64x1  xor()   404 MB/s
[    0.452316] raid6: int64x2  gen()   619 MB/s
[    0.520305] raid6: int64x2  xor()   548 MB/s
[    0.588388] raid6: int64x4  gen()   902 MB/s
[    0.656402] raid6: int64x4  xor()   677 MB/s
[    0.724431] raid6: int64x8  gen()  1049 MB/s
[    0.792485] raid6: int64x8  xor()   684 MB/s
[    0.860604] raid6: neonx1   gen()   662 MB/s
[    0.928601] raid6: neonx1   xor()   695 MB/s
[    0.996621] raid6: neonx2   gen()  1069 MB/s
[    1.064692] raid6: neonx2   xor()   948 MB/s
[    1.132744] raid6: neonx4   gen()  1379 MB/s
[    1.200785] raid6: neonx4   xor()  1083 MB/s
[    1.268836] raid6: neonx8   gen()  1454 MB/s
[    1.336880] raid6: neonx8   xor()  1119 MB/s
[    1.336893] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.336906] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.336919] raid6: using intx1 recovery algorithm
[    1.337388] GPIO IRQ not connected
[    1.337402] XGpio: /amba_pl@0/gpio@80000000: registered, base is 509
[    1.337625] GPIO IRQ not connected
[    1.337639] XGpio: /amba_pl@0/gpio@80001000: registered, base is 501
[    1.338402] SCSI subsystem initialized
[    1.338647] usbcore: registered new interface driver usbfs
[    1.338696] usbcore: registered new interface driver hub
[    1.338744] usbcore: registered new device driver usb
[    1.338830] media: Linux media interface: v0.10
[    1.338869] Linux video capture interface: v2.00
[    1.338909] pps_core: LinuxPPS API ver. 1 registered
[    1.338922] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.338955] PTP clock support registered
[    1.338993] EDAC MC: Ver: 3.0.0
[    1.339314] FPGA manager framework
[    1.339466] fpga-region fpga-full: FPGA Region probed
[    1.339575] Advanced Linux Sound Architecture Driver Initialized.
[    1.339924] Bluetooth: Core ver 2.22
[    1.339964] NET: Registered protocol family 31
[    1.339977] Bluetooth: HCI device and connection manager initialized
[    1.339995] Bluetooth: HCI socket layer initialized
[    1.340011] Bluetooth: L2CAP socket layer initialized
[    1.340035] Bluetooth: SCO socket layer initialized
[    1.340655] clocksource: Switched to clocksource arch_sys_counter
[    1.340761] VFS: Disk quotas dquot_6.6.0
[    1.340816] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.346203] NET: Registered protocol family 2
[    1.346610] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.346744] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.347043] TCP: Hash tables configured (established 16384 bind 16384)
[    1.347125] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.347179] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.347336] NET: Registered protocol family 1
[    1.347591] RPC: Registered named UNIX socket transport module.
[    1.347606] RPC: Registered udp transport module.
[    1.347619] RPC: Registered tcp transport module.
[    1.347631] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.348078] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.348960] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.349050] audit: initializing netlink subsys (disabled)
[    1.349087] audit: type=2000 audit(1.336:1): initialized
[    1.349618] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.350301] NFS: Registering the id_resolver key type
[    1.350328] Key type id_resolver registered
[    1.350341] Key type id_legacy registered
[    1.350359] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.350388] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.355112] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.355136] io scheduler noop registered
[    1.355148] io scheduler deadline registered
[    1.355167] io scheduler cfq registered (default)
[    1.356396] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.356739] Write failed gate address:1000f02
[    1.356873] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.357024] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.357166] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.357314] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.357458] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.357598] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.357741] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.357884] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.358101] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.358245] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.358388] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.358534] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.358679] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.358823] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.358965] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.359109] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.359304] zynqmp_pm firmware: Power management API v0.3
[    1.359421] xenfs: not registering filesystem on non-xen platform
[    1.391502] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.392963] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[    2.396104] console [ttyPS0] enabled
[    2.400034] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[    2.409229] [drm] Initialized
[    2.412478] [drm] load() is defered & will be called again
[    2.418394] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
[    2.426329] Unable to detect cache hierarchy from DT for CPU 0
[    2.437437] brd: module loaded
[    2.443721] loop: module loaded
[    2.447695] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.456600] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.467184] scsi host0: ahci-ceva
[    2.470665] scsi host1: ahci-ceva
[    2.474058] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    2.481912] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    2.489969] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.497243] m25p80 spi0.0: found n25q256a, expected n25q512a
[    2.502948] m25p80 spi0.0: n25q256a (65536 Kbytes)
[    2.507679] 3 ofpart partitions found on MTD device spi0.0
[    2.513131] Creating 3 MTD partitions on "spi0.0":
[    2.517907] 0x000000000000-0x000000100000 : "boot"
[    2.523263] 0x000000100000-0x000000140000 : "bootenv"
[    2.528773] 0x000000140000-0x000001740000 : "kernel"
[    2.535104] libphy: Fixed MDIO Bus: probed
[    2.540354] tun: Universal TUN/TAP device driver, 1.6
[    2.545343] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.551651] CAN device driver interface
[    2.555992] macb ff0e0000.ethernet: Not enabling partial store and forward
[    2.563338] libphy: MACB_mii_bus: probed
[    2.569541] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    2.617279] usbcore: registered new interface driver asix
[    2.622654] usbcore: registered new interface driver ax88179_178a
[    2.628710] usbcore: registered new interface driver cdc_ether
[    2.634524] usbcore: registered new interface driver net1080
[    2.640166] usbcore: registered new interface driver cdc_subset
[    2.646069] usbcore: registered new interface driver zaurus
[    2.651635] usbcore: registered new interface driver cdc_ncm
[    2.657630] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.664081] ehci-pci: EHCI PCI platform driver
[    2.668756] usbcore: registered new interface driver uas
[    2.674030] usbcore: registered new interface driver usb-storage
[    2.680298] mousedev: PS/2 mouse device common for all mice
[    2.686255] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.693442] i2c /dev entries driver
[    2.697098] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.704004] usbcore: registered new interface driver uvcvideo
[    2.709678] USB Video Class driver (1.1.1)
[    2.714377] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff8008f61000 with timeout 10s
[    2.723441] Bluetooth: HCI UART driver ver 2.3
[    2.727811] Bluetooth: HCI UART protocol H4 registered
[    2.732928] Bluetooth: HCI UART protocol BCSP registered
[    2.738221] Bluetooth: HCI UART protocol LL registered
[    2.743342] Bluetooth: HCI UART protocol ATH3K registered
[    2.748724] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.755014] Bluetooth: HCI UART protocol Intel registered
[    2.760395] Bluetooth: HCI UART protocol Broadcom registered
[    2.765999] Bluetooth: HCI UART protocol QCA registered
[    2.771245] usbcore: registered new interface driver bcm203x
[    2.776884] usbcore: registered new interface driver bpa10x
[    2.782437] usbcore: registered new interface driver bfusb
[    2.787905] usbcore: registered new interface driver btusb
[    2.793341] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.799036] usbcore: registered new interface driver ath3k
[    2.802899] ata1: SATA link down (SStatus 0 SControl 330)
[    2.802933] ata2: SATA link down (SStatus 0 SControl 330)
[    2.815343] EDAC MC: ECC not enabled
[    2.819012] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.831635] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    2.839023] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.847899] sdhci: Secure Digital Host Controller Interface driver
[    2.854008] sdhci: Copyright(c) Pierre Ossman
[    2.858344] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.912672] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.968663] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    2.976834] ledtrig-cpu: registered to indicate activity on CPUs
[    2.982906] usbcore: registered new interface driver usbhid
[    2.988403] usbhid: USB HID core driver
[    2.996029] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.002943] xilinx-dp-snd-pcm dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.010145] xilinx-dp-snd-pcm dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.017481] PLL: shutdown
[    3.020948] Two devices are using vpll which is forbidden
[    3.026313] ------------[ cut here ]------------
[    3.030877] WARNING: CPU: 0 PID: 1 at /home/vishal/myprj/build/tmp/work-shared/plnx_aarch64/kernel-source/drivers/clk/zynqmp/pll.c:190 zynqmp_pll_set_rate+0x200/0x220
[    3.045725] Modules linked in:
[    3.048744]
[    3.050224] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.3 #1
[    3.057342] Hardware name: xlnx,zynqmp (DT)
[    3.061507] task: ffffffc06d866c00 task.stack: ffffffc06d868000
[    3.067412] PC is at zynqmp_pll_set_rate+0x200/0x220
[    3.072358] LR is at zynqmp_pll_set_rate+0x200/0x220
[    3.077305] pc : [<ffffff8008459aa0>] lr : [<ffffff8008459aa0>] pstate: 60000045
[    3.084689] sp : ffffffc06d86bb20
[    3.087980] x29: ffffffc06d86bb20 x28: 0000000000000000
[    3.093273] x27: ffffff8008c7e298 x26: ffffff8008d45000
[    3.098567] x25: 0000000001588800 x24: 0000000000000000
[    3.103863] x23: ffffffc06daa9810 x22: ffffffc06da5e180
[    3.109157] x21: 0000000001fca055 x20: 0000000001fca055
[    3.114452] x19: 000000005ad20000 x18: 0000000000000010
[    3.119747] x17: 0000000000000000 x16: 0000000000000000
[    3.125042] x15: 0000000000000006 x14: ffffff8088d4a1d7
[    3.130336] x13: ffffff8008d4a1e5 x12: 0000000000000108
[    3.135632] x11: ffffffc06d86b880 x10: 0000000000000109
[    3.140927] x9 : 000000000000003d x8 : 62726f6620736920
[    3.146221] x7 : 6863696877206c6c x6 : ffffff8008d4a214
[    3.151516] x5 : ffffff800843f498 x4 : 0000000000000000
[    3.156811] x3 : 0000000000000000 x2 : 00000000000005f9
[    3.162106] x1 : ffffff8008cca9c8 x0 : 000000000000002d
[    3.167400]
[    3.168881] ---[ end trace ccee47c6397f171b ]---
[    3.173480] Call trace:
[    3.175911] Exception stack(0xffffffc06d86b950 to 0xffffffc06d86ba80)
[    3.182336] b940:                                   000000005ad20000 0000008000000000
[    3.190155] b960: ffffffc06d86bb20 ffffff8008459aa0 ffffff8008d4c5f8 000000000000002d
[    3.197967] b980: ffffffc06d86b9a0 ffffff80080d908c ffffff8008d49c68 ffffff8008aea720
[    3.205779] b9a0: ffffffc06d86ba40 ffffff80080d9364 000000005ad20000 0000000001fca055
[    3.213591] b9c0: 0000000001fca055 ffffffc06da5e180 ffffffc06daa9810 0000000000000000
[    3.221403] b9e0: 0000000001588800 ffffff8008d45000 000000000000002d ffffff8008cca9c8
[    3.229215] ba00: 00000000000005f9 0000000000000000 0000000000000000 ffffff800843f498
[    3.237027] ba20: ffffff8008d4a214 6863696877206c6c 62726f6620736920 000000000000003d
[    3.244839] ba40: 0000000000000109 ffffffc06d86b880 0000000000000108 ffffff8008d4a1e5
[    3.252651] ba60: ffffff8088d4a1d7 0000000000000006 0000000000000000 0000000000000000
[    3.260464] [<ffffff8008459aa0>] zynqmp_pll_set_rate+0x200/0x220
[    3.266448] [<ffffff80084547d8>] clk_change_rate+0x1e0/0x238
[    3.272090] [<ffffff8008454890>] clk_core_set_rate_nolock+0x60/0xc8
[    3.278338] [<ffffff8008454920>] clk_set_rate+0x28/0x58
[    3.283547] [<ffffff8008733df8>] xilinx_dp_codec_probe+0xd8/0x1e8
[    3.289624] [<ffffff8008504180>] platform_drv_probe+0x58/0xc0
[    3.295353] [<ffffff8008502624>] driver_probe_device+0x1fc/0x2a8
[    3.301341] [<ffffff800850277c>] __driver_attach+0xac/0xb0
[    3.306809] [<ffffff8008500674>] bus_for_each_dev+0x64/0xa0
[    3.312364] [<ffffff8008501e10>] driver_attach+0x20/0x28
[    3.317659] [<ffffff8008501960>] bus_add_driver+0x110/0x230
[    3.323215] [<ffffff8008502f60>] driver_register+0x60/0xf8
[    3.328682] [<ffffff80085040b8>] __platform_driver_register+0x40/0x48
[    3.335108] [<ffffff8008c60f8c>] xilinx_dp_codec_driver_init+0x18/0x20
[    3.341618] [<ffffff80080830b8>] do_one_initcall+0x38/0x128
[    3.347172] [<ffffff8008c30c94>] kernel_init_freeable+0x140/0x1e0
[    3.353248] [<ffffff8008946548>] kernel_init+0x10/0x100
[    3.358455] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    3.363960] Write failed to divider address:fd1a00c0
[    3.369218] PLL: enable
[    3.371780] xilinx-dp-snd-codec dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.379887] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.389635] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.399654] xilinx-dp-snd-card dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.407085] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    3.415865] Netfilter messages via NETLINK v0.30.
[    3.420625] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.425919] Initializing XFRM netlink socket
[    3.430172] NET: Registered protocol family 10
[    3.435021] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.440400] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.446637] NET: Registered protocol family 17
[    3.451020] NET: Registered protocol family 15
[    3.455451] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.468380] Ebtables v2.0 registered
[    3.471975] can: controller area network core (rev 20120528 abi 9)
[    3.476360] mmc0: new HS200 MMC card at address 0001
[    3.476633] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    3.476749] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    3.476854] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    3.476956] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    3.477756]  mmcblk0: p1
[    3.507713] NET: Registered protocol family 29
[    3.509390] mmc1: error -110 whilst initialising SD card
[    3.517414] can: raw protocol (rev 20120528)
[    3.521661] can: broadcast manager protocol (rev 20161123 t)
[    3.527305] can: netlink gateway (rev 20130117) max_hops=1
[    3.532832] Bluetooth: RFCOMM TTY layer initialized
[    3.537640] Bluetooth: RFCOMM socket layer initialized
[    3.542769] Bluetooth: RFCOMM ver 1.11
[    3.546489] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.551780] Bluetooth: BNEP filters: protocol multicast
[    3.556991] Bluetooth: BNEP socket layer initialized
[    3.561936] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.567841] Bluetooth: HIDP socket layer initialized
[    3.572981] 9pnet: Installing 9P2000 support
[    3.577184] Key type dns_resolver registered
[    3.581861] registered taskstats version 1
[    3.586323] Btrfs loaded, crc32c=crc32c-generic
[    3.601571] [drm] load() is defered & will be called again
[    3.607690] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
[    3.615712] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
[    3.621817] xilinx-drm-dp fd4a0000.dp: Display Port, version 1.0200 (tx)
[    3.629755] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.635176] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.643084] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x02010010
[    3.651745] xhci-hcd xhci-hcd.0.auto: irq 220, io mem 0xfe200000
[    3.657822] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.664539] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.671748] usb usb1: Product: xHCI Host Controller
[    3.676601] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.3 xhci-hcd
[    3.683202] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.688377] hub 1-0:1.0: USB hub found
[    3.692072] hub 1-0:1.0: 1 port detected
[    3.696135] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.701556] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.709241] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.717346] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.724058] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.731277] usb usb2: Product: xHCI Host Controller
[    3.736121] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.3 xhci-hcd
[    3.742718] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.747867] hub 2-0:1.0: USB hub found
[    3.751554] hub 2-0:1.0: 1 port detected
[    3.756583] OF: graph: no port node found in /xilinx_drm
[    3.761826] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.768418] [drm] No driver support for vblank timestamp query.
[    3.798680] Two devices are using vpll which is forbidden
[    3.798720] ------------[ cut here ]------------
[    3.798733] WARNING: CPU: 1 PID: 434 at /home/vishal/myprj/build/tmp/work-shared/plnx_aarch64/kernel-source/drivers/clk/zynqmp/pll.c:190 zynqmp_pll_set_rate+0x200/0x220
[    3.798737] Modules linked in:
[    3.798739]
[    3.798745] CPU: 1 PID: 434 Comm: kworker/1:1 Tainted: G        W       4.9.0-xilinx-v2017.3 #1
[    3.798746] Hardware name: xlnx,zynqmp (DT)
[    3.798757] Workqueue: events deferred_probe_work_func
[    3.798759] task: ffffffc06cf75000 task.stack: ffffffc06ce28000
[    3.798762] PC is at zynqmp_pll_set_rate+0x200/0x220
[    3.798765] LR is at zynqmp_pll_set_rate+0x200/0x220
[    3.798768] pc : [<ffffff8008459aa0>] lr : [<ffffff8008459aa0>] pstate: 80000045
[    3.798769] sp : ffffffc06ce2b180
[    3.798773] x29: ffffffc06ce2b180 x28: ffffffc06d3a43a0
[    3.798777] x27: ffffffc06c9c6018 x26: ffffffc06d3a43a8
[    3.798780] x25: ffffffc06c9c6018 x24: 0000000000000000
[    3.798784] x23: 0000000000000000 x22: ffffffc06d984b80
[    3.798787] x21: 0000000001fca055 x20: 0000000001fca055
[    3.798791] x19: 000000005a1f4a00 x18: 0000000000000000
[    3.798794] x17: 0000000000000000 x16: 0000000000000000
[    3.798798] x15: 0000000000010000 x14: 00000000fffffff0
[    3.798801] x13: ffffff8008cca9b0 x12: ffffff8008d4c5f8
[    3.798805] x11: ffffff8008cca000 x10: ffffff8008d49000
[    3.798808] x9 : 0000000000000000 x8 : ffffff8008d539f3
[    3.798812] x7 : 0000000000000000 x6 : 00000000f02829fe
[    3.798815] x5 : 00ffffffffffffff x4 : 0000000000000000
[    3.798818] x3 : 0000000000000000 x2 : 0000000000000368
[    3.798822] x1 : 0000000000000040 x0 : 000000000000002d
[    3.798822]
[    3.798824] ---[ end trace ccee47c6397f171d ]---
[    3.798826] Call trace:
[    3.798830] Exception stack(0xffffffc06ce2afb0 to 0xffffffc06ce2b0e0)
[    3.798833] afa0:                                   000000005a1f4a00 0000008000000000
[    3.798837] afc0: ffffffc06ce2b180 ffffff8008459aa0 ffffff8008ccaa18 0000000000000000
[    3.798841] afe0: ffffffc06ce2b000 ffffff80080d908c ffffff8008d49c68 ffffff8008cca9b0
[    3.798845] b000: ffffffc06ce2b0a0 ffffff80080d9364 000000005a1f4a00 0000000001fca055
[    3.798848] b020: 0000000001fca055 ffffffc06d984b80 0000000000000000 0000000000000000
[    3.798852] b040: ffffffc06c9c6018 ffffffc06d3a43a8 000000000000002d 0000000000000040
[    3.798856] b060: 0000000000000368 0000000000000000 0000000000000000 00ffffffffffffff
[    3.798860] b080: 00000000f02829fe 0000000000000000 ffffff8008d539f3 0000000000000000
[    3.798863] b0a0: ffffff8008d49000 ffffff8008cca000 ffffff8008d4c5f8 ffffff8008cca9b0
[    3.798867] b0c0: 00000000fffffff0 0000000000010000 0000000000000000 0000000000000000
[    3.798871] [<ffffff8008459aa0>] zynqmp_pll_set_rate+0x200/0x220
[    3.798876] [<ffffff80084547d8>] clk_change_rate+0x1e0/0x238
[    3.798881] [<ffffff8008454890>] clk_core_set_rate_nolock+0x60/0xc8
[    3.798885] [<ffffff8008454920>] clk_set_rate+0x28/0x58
[    3.798891] [<ffffff80084f3580>] xilinx_drm_crtc_mode_set+0x48/0x220
[    3.798898] [<ffffff80084bec5c>] drm_crtc_helper_set_mode+0x31c/0x4b0
[    3.798903] [<ffffff80084bf7c8>] drm_crtc_helper_set_config+0x888/0x9a0
[    3.798909] [<ffffff80084dc548>] drm_mode_set_config_internal+0x60/0xf0
[    3.798915] [<ffffff80084ccedc>] restore_fbdev_mode+0x20c/0x2d8
[    3.798920] [<ffffff80084ce98c>] drm_fb_helper_restore_fbdev_mode_unlocked+0x34/0x90
[    3.798924] [<ffffff80084ce7ac>] drm_fb_helper_set_par+0x2c/0x68
[    3.798929] [<ffffff8008440f90>] fbcon_init+0x508/0x558
[    3.798934] [<ffffff80084994b4>] visual_init+0xb4/0x108
[    3.798937] [<ffffff800849a8a0>] do_bind_con_driver+0x1b8/0x3a0
[    3.798941] [<ffffff800849ae48>] do_take_over_console+0x150/0x1d0
[    3.798945] [<ffffff8008441054>] do_fbcon_takeover+0x74/0xf8
[    3.798949] [<ffffff800844497c>] fbcon_event_notify+0x92c/0x958
[    3.798955] [<ffffff80080b8290>] notifier_call_chain+0x50/0x90
[    3.798959] [<ffffff80080b85e4>] __blocking_notifier_call_chain+0x4c/0x90
[    3.798963] [<ffffff80080b863c>] blocking_notifier_call_chain+0x14/0x20
[    3.798968] [<ffffff800844698c>] fb_notifier_call_chain+0x1c/0x28
[    3.798972] [<ffffff8008448b84>] register_framebuffer+0x1cc/0x2d8
[    3.798976] [<ffffff80084ce620>] drm_fb_helper_initial_config+0x288/0x3e8
[    3.798981] [<ffffff80084f5424>] xilinx_drm_fb_init+0xac/0x190
[    3.798985] [<ffffff80084f4770>] xilinx_drm_load+0x2b0/0x328
[    3.798989] [<ffffff80084d8714>] drm_dev_register+0xbc/0xe0
[    3.798993] [<ffffff80084da270>] drm_platform_init+0x70/0xc0
[    3.798997] [<ffffff80084f4314>] xilinx_drm_platform_probe+0x1c/0x28
[    3.799001] [<ffffff8008504180>] platform_drv_probe+0x58/0xc0
[    3.799006] [<ffffff8008502624>] driver_probe_device+0x1fc/0x2a8
[    3.799010] [<ffffff800850281c>] __device_attach_driver+0x9c/0xf8
[    3.799014] [<ffffff8008500734>] bus_for_each_drv+0x5c/0x98
[    3.799019] [<ffffff8008502304>] __device_attach+0xc4/0x138
[    3.799023] [<ffffff80085028d8>] device_initial_probe+0x10/0x18
[    3.799027] [<ffffff800850172c>] bus_probe_device+0x94/0xa0
[    3.799031] [<ffffff8008501bac>] deferred_probe_work_func+0x74/0xa8
[    3.799037] [<ffffff80080b0ef4>] process_one_work+0x1bc/0x380
[    3.799041] [<ffffff80080b130c>] worker_thread+0x254/0x4a8
[    3.799045] [<ffffff80080b6d14>] kthread+0xd4/0xe8
[    3.799049] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    3.831958] Console: switching to colour frame buffer device 160x64
[    4.109770] random: fast init done
[    4.443839] xilinx-drm xilinx_drm: fb0:  frame buffer device
[    4.508663] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
[    4.517391] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:22 UTC (22)
[    4.528044] clk: Not disabling unused clocks
[    4.534738] ALSA device list:
[    4.540081]   #0: DisplayPort monitor
[    4.546736] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -6
[    4.557142] Please append a correct "root=" boot option; here are the available partitions:
[    4.568017] 0100           65536 ram0 [    4.571548]  (driver?)
[    4.576434] 0101           65536 ram1 [    4.579959]  (driver?)
[    4.584830] 0102           65536 ram2 [    4.588357]  (driver?)
[    4.593197] 0103           65536 ram3 [    4.596722]  (driver?)
[    4.601508] 0104           65536 ram4 [    4.605035]  (driver?)
[    4.609794] 0105           65536 ram5 [    4.613316]  (driver?)
[    4.618058] 0106           65536 ram6 [    4.621588]  (driver?)
[    4.626309] 0107           65536 ram7 [    4.629834]  (driver?)
[    4.634530] 0108           65536 ram8 [    4.638054]  (driver?)
[    4.642738] 0109           65536 ram9 [    4.646266]  (driver?)
[    4.650920] 010a           65536 ram10 [    4.654530]  (driver?)
[    4.659175] 010b           65536 ram11 [    4.662793]  (driver?)
[    4.667405] 010c           65536 ram12 [    4.671023]  (driver?)
[    4.675600] 010d           65536 ram13 [    4.679216]  (driver?)
[    4.683744] 010e           65536 ram14 [    4.687359]  (driver?)
[    4.691867] 010f           65536 ram15 [    4.695484]  (driver?)
[    4.699979] 1f00            1024 mtdblock0 [    4.703942]  (driver?)
[    4.708443] 1f01             256 mtdblock1 [    4.712405]  (driver?)
[    4.716889] 1f02           22528 mtdblock2 [    4.720850]  (driver?)
[    4.725315] b300         7438336 mmcblk0 [    4.729104]  driver: mmcblk
[    4.734029]   b301          250040 mmcblk0p1 00000000-01[    4.739133]
[    4.742746] b318            4096 mmcblk0rpmb [    4.746884]  (driver?)
[    4.751386] b310           16384 mmcblk0boot1 [    4.755617]  (driver?)
[    4.760109] b308           16384 mmcblk0boot0 [    4.764339]  (driver?)
[    4.768815] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[    4.779424] CPU: 1 PID: 1 Comm: swapper/0 Tainted: G        W       4.9.0-xilinx-v2017.3 #1
[    4.789986] Hardware name: xlnx,zynqmp (DT)
[    4.796372] Call trace:
[    4.801014] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[    4.808635] [<ffffff80080882e4>] show_stack+0x14/0x20
[    4.815907] [<ffffff80083de514>] dump_stack+0x94/0xb8
[    4.823170] [<ffffff800812e9a8>] panic+0x114/0x25c
[    4.830157] [<ffffff8008c310e8>] mount_block_root+0x198/0x270
[    4.838107] [<ffffff8008c313f8>] mount_root+0x11c/0x134
[    4.845512] [<ffffff8008c3157c>] prepare_namespace+0x16c/0x1b4
[    4.853532] [<ffffff8008c30d14>] kernel_init_freeable+0x1c0/0x1e0
[    4.861813] [<ffffff8008946548>] kernel_init+0x10/0x100
[    4.869208] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    4.876691] SMP: stopping secondary CPUs
[    4.882792] Kernel Offset: disabled
[    4.888456] Memory Limit: none
[    4.893665] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
also i came to know this was resolved (https://forums.xilinx.com/t5/Embedded-Development-Tools/Beginners-problems-with-Ultrazed-eg/td-p/800802) by adding disable-wp to system-tops.dts file which also includes system-user.dtsi file
&sdhci1 {
status = "okay";
max-frequency = <50000000>;
no-1-8-v; /* for 1.0 silicon */
disable-wp;
the system-tops.dts file under path : project-root/components/plnx-workspace/device-tree/device-tree-generation/ does not have &sdhci0 and &sdhci1 defined in it
system-user.dtsi under path : project-root/project-spec/meta-user/recipes-bsp/device-tree/  has only this :
/include/ "system-conf.dtsi"
even the system-conf.dtsi also does not have that declration of &sdhci1 and &sdhci0 in it. I f i add these in system-user.dtsi. i start getting error
* Unable to read file system.dtb *
and some times yocto within the petalinux folder  starts giving error : oe_runamke failed
I had to re-install petalinux to get the issue of unreadable system.dtb rectified, but still i am not able to solve the SD boot issue.
I was also getting PLL:shutdown error.  After following this : https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/PLL-shutdown-when-Display-Port-is-enabled-in-the-devicetree/td-p/785164
i started getting the unreadable system.dtb error as well .
Any help is much appreciated. I need to resolve this issue quick now.
Re: Kernel Panic and SD boot issue
