Kernel build and install process error
I am trying to compile the kernel version 4.9.0 from xilinx (can be found here: https://github.com/Xilinx/linux-xlnx), and install it in a custom subdirectory (to been copied into uSD later).
The build process end up right.
The install process fails, with the following error:
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.9.10-xilinx /path/to/kernel/source/linux-kernels/xilinx/linux-4.9.10/install/vmlinuz-4.9.10-xilinx
/etc/kernel/postinst.d/apt-auto-removal: 84: /etc/kernel/postinst.d/apt-auto-removal: cannot create /etc/apt/apt.conf.d//01autoremove-kernels.dpkg-new: Permission denied
run-parts: /etc/kernel/postinst.d/apt-auto-removal exited with return code 2
arch/arm/boot/Makefile:96: recipe for target 'install' failed
make[2]: *** [install] Error 1
arch/arm/Makefile:333: recipe for target 'install' failed
make[1]: *** [install] Error 2
Makefile:525: recipe for target '__build_one_by_one' failed
make: *** [__build_one_by_one] Error 2
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property
As it seems, the install process tries to access to my system directories, which of course is not what I want.
The problem does not come up when I try to compile a kernel version 4.1.33 with the same exact method.
Do you have an idea or any suggestion to what is causing this problem and how to solve ?
Thank you in advance.
Simon
Re: Kernel build and install process error
you don't have write permission in destination folder,
try to change the destination
make install DESTDIR=/somewhere/else
build should pass but the devicetree seems corrupted
G.W.,
NIST - Time Frequency metrology
Hello @guillaumebres,
Well, I create the destination folder.
The script used to execute the make command is the same I used for an older kernel, which works.
The problem is related with the script
/arch/arm/boot/install.sh
When is executed by the build process, the command line is:
/bin/bash ./arch/arm/boot/install.sh "4.9.10-s-1.0.0"
Looking at arch/arm/boot/install.sh it results that this script takes 4 arguments:
#!/bin/sh
# arch/arm/boot/install.sh
# This file is subject to the terms and conditions of the GNU General Public
# License.  See the file "COPYING" in the main directory of this archive
# for more details.
# Copyright (C) 1995 by Linus Torvalds
# Adapted from code in arch/i386/boot/Makefile by H. Peter Anvin
# Adapted from code in arch/i386/boot/install.sh by Russell King
# "make install" script for arm architecture
# Arguments:
#   $1 - kernel version
#   $2 - kernel image file
#   $3 - kernel map file
#   $4 - default install path (blank if root directory)
$2, $3 & $4 are missing. I still don't know why..
Simon
Do someone from the Xilinx staff knows how to solve this problem ?
Thank you,
Simon
Visitor madisonquinn
This will copy all the modules to a new directory, "/lib/modules/a.b.c" where a.b.c is the kernel version
make modules_install
Installing with dpkg
Using apt is so convenient that it makes it easy to forget about the lower-level tools, but the easiest way of installing a compiled kernel is to use a command such as dpkg -i package.deb, where package.deb is the name of a linux-image package such as linux-image-3.16.7-ckt4-falcot_1_amd64.deb.
The configuration steps described in this chapter are basic and can lead both to a server system or a workstation, and it can be massively duplicated in semi-automated ways. However, it is not enough by itself to provide a fully configured system. A few pieces are still in need of configuration, starting with low-level programs known as the “Unix services”.
Hello @madisonquinn
The problem happens only with linux-xlnx kernel.
The make command I use to compile is:
make all uImage modules_install install INSTALL_PATH=${INSTALLDIR} INSTALL_MOD_PATH=${INSTALLDIR} ARCH=arm CROSS_COMPILE=${CROSS} LOADADDR=${LOADADDR}
where INSTALLDIR is a custom local dir inside the kernel source directory.
This command works fine with older kernel sources (e.g. 4.1.33).
Simon
There should be recipe provided to do this in the recipes-kernel/linux area.  There is a recipe for pulling in the prebuilt.  Where is the recipe that creates that?
Newbie jyothi_9
it is very much useful for me to understand many concepts and helped me a lot.
web-methods training
windows-server training
