Kernel doesn't boot after patch
Had to remove it sorry..
Re: Kernel doesn't boot after patch
Hi Senna
Does the boot succeeds without this patch?
What does the patch consists of and also may I know the petalinux version being used?
Best Regards
Shabbir
Hi Senna
May I know what is that you are trying to change in your patch, I mean your requirement?
Best Regards
Shabbir
Hi @shabbirk,
What you mean by requirement?
This is what I am trying to achieve:
The Zynq SoC is not connected to an Ethernet physical. Instead it uses an Ethernet switch as the 5 physical. Unfortunately this means, since the MDIO bus is not connected, that the Linux kernel cannot detect a physical, which is normally done via the MDIO bus.
Greetings :)
Anybody have some more suggestions? I tested when I only add a printf to the phy_fixed.c instead of all that extra code it doesn't boot either. I don't know what to do..
