Observer benzao
Kernel hangs at "mmc0: no vmmc regulator found"
i use "git pull" for linux_xlnx and compile linux kernel again,
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.14.0-xilinx (root@ubuntu) (gcc version 4.7.3 (Sourcery CodeBench
Lite 2013.05-40) ) #1 SMP PREEMPT Sat Jul 12 21:42:39 PDT 2014
Machine model: Xilinx Zynq
cma: CMA: reserved 128 MiB at 17400000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @dfba0000 s9024 r8192 d15552 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyPS0,115200
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 377684K/524288K available (4596K kernel code, 232K rwdata, 1536K rodata,
188K init, 192K bss, 146604K reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc06055ac (6134 kB)
.init : 0xc0606000 - 0xc0635340 ( 189 kB)
.data : 0xc0636000 - 0xc06701a0 ( 233 kB)
.bss : 0xc06701ac - 0xc06a033c ( 193 kB)
Dump stacks of tasks blocking RCU-preempt GP.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
ps7-slcr mapped to e0802000
zynq_clock_init: clkc starts at e0802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
Calibrating delay loop... 1325.46 BogoMIPS (lpj=6627328)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
missing device node for CPU 0
missing device node for CPU 1
Setting up static identity map for 0x457aa8 - 0x457b00
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72760000, Cache size: 512 kB
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
syscon f8000000.ps7-slcr: regmap [mem 0xf8000000-0xf8000fff] registered
zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0880000
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@l
inux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 3856K (df78b000 - dfb4f000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 1001
io scheduler noop registered
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-267056
dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Even
ts-16
xuartps e0000000.serial: clock name 'aper_clk' is deprecated.
xuartps e0000000.serial: clock name 'ref_clk' is deprecated.
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 59, base_baud = 3124999) is a
xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to e0862000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.ps7-i2c: 400 kHz mmio e0004000 irq 57
zynq-edac f8006000.ps7-ddrc: ecc not enabled
cpufreq_cpu0: failed to find cpu0 node
cpufreq-cpu0: probe of cpufreq-cpu0.0 failed with error -2
Xilinx Zynq CpuIdle Driver started
mmc0: no vqmmc regulator found
Re: Kernel hangs at "mmc0: no vmmc regulator found"
You don't give much details that might help.  What board are you using?
Did it work before the pull and now it's not?
Did you regenerate the device tree to match the kernel or use a device tree in the kernel?  The device tree changes between kernel versions and may not be compatible if your kernel version changed.
John
Visitor sadiaq
I am having exactly the same issue
I am using the microzed 7020 board and have compiled the linux-xlnx kernel from github.
The distribution is Xillinux but it doesnt even load the kernel properly.
I am trying to run the sample code that comes with Xillinux .
Please help
Scholar trenz-al
1 you can add fixed regulator in device tree this makes the warning go away
2 please use petalinux 2014.2 evcerything else is wast of time.. my2cent
Visitor ashiar01
We have the exact same issue. The last suggestion applies to removing the warning and not the hang itself.
We are using a custom board with a Z7030 with Petalinux 2014.2 The devicetree is imported as described in the UG. This issue happens on some of the builds and not others. The only changes to the build are in the PL so it shouldn't be affecting this. I have played around with the PL changes and it seems like the break is random rather than depending on certain logic being present or not.
Scholar trenz-al
thats is weird - 2014.2 seems rather stable
and the mmc regulator warning I think is not related the real problem
Visitor ali.ebrahimi
I am dealing with the same problem since a few days with no solution. I am using a Mars ZX3 Module on a custom board. The board is using a micro SD card. Since I am usign the SD card to boot from and micro SD does not provide CD and WP signals, I had to modify the zynq boot loader so it ignores card detection. It works fine and u-boot detects the card.
But as mentioned in the first post, it hangs when the kerenl starts and reaches the point where it loads SDHCI driver for the SD card.
I tried adding broken-cd and broken-wp to the device tree and it didn't help.
I'm using Vivado and Petalinux 14.2 and latest linux kernel 3.14 which comes with the peta linux.
Scholar milosoftware
"broken-wp" does not exist. I submitted a patch to add support for it, but it was never accepted.
Connect the CD and WP lines to EMIO, do not set them as unused in Vivado (Vivado <= 2014.1 will connect unused WP/CD pins to MIO 0 instead of tying them to EMIO)
There is an "invert" property (wp-inverted or something like that) that you can then use to make the WP line being seen as correct if it isn't already.
Thank you for the reply.
I have tried connecting the CD and WP pins to EMIO and made them external. Then in the PL I set WP= '0' and CD = '1' or CD = '0' and none of them worked.
Scholar trenz-al
kernel would not hang no matter the CD or WP settings, its irrelevant
benzao -- can you please post your 2014.2 DTS and DTSI files? Are you sure that you have the TTC defined in them?
this space intentionally left blank
Please see the files attached. There are two TTC defined in ps.dtsi.
I took a quick look at your DTS files and I see the TTC's there as well.  The *important* thing though is that their status is marked as "disabled."
Embedded Linux on Zynq requires at least one TTC for use as a system timer.  Double-check your hardware design in Vivado to ensure that you've enabled the Zynq PS TTC.  Once it's enabled, re-implement the design in Vivado and re-export over to PetaLinux.  The DTS will be updated and then you'll see it show up without the "disabled" flag.
Indeed, you're right. If the WP or CD signal were the problem, the kernel would "panic" there and complain about not being able to mount the root.
If the root filesystem is ext3/4, the kernel will also fail to mount it if it's read-only, even if you attempt to mount it "ro". This is because of the journal "playback" if the filesystem is in an inconsistent state.
Thanks a lot tmcdowe. Enabling TTC routed to EMIO solved the problem.
I can't find the option to mark your answer as a solution, perhaps because I'm not the one who has started the thread.
