Observer 32100004
Linux DMA tx channel not found
  I'm working on DMA for days.I've learned how to use DMA IP in linux with data loopback. However,when I try to cut down the loop and only use the rx channel to send data to memory, I meet with problems.I use TPG to produce data and send it to DMA through AXIS bus,and the Constant set to 1. When I get linux started and try to insmod the driver, I cannot get an expected result as the system cannot find tx device for data transfer.
The UART's Output:
zynq> insmod hello.ko
enter dma chanel
zfdriver: tx match is 100001
zfdriver: rx match is 100002
zfdriver: Did not find tx device
zfdriver: Found rx device
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 5a618000
[00000000] *pgd=1f5f9831, *pte=00000000, *ppte=00000000
Internal error: Oops - BUG: 17 [#1] PREEMPT SMP ARM
Modules linked in: hello(O+)
CPU: 1 PID: 589 Comm: insmod Tainted: G           O   3.17.0-xilinx #7
task: 5f527ac0 ti: 5f728000 task.ti: 5f728000
PC is at axi_dma_init+0xb0/0x4a8 [hello]
LR is at axi_dma_init+0xb0/0x4a8 [hello]
pc : [<3f0000ec>]    lr : [<3f0000ec>]    psr: 60000013
sp : 5f729da8  ip : 00000000  fp : 5f729f58
r10: 00000001  r9 : 00000000  r8 : 3f00003c
r7 : 5f5d9e80  r6 : 40663598  r5 : 00000000  r4 : 5f7724f4
r3 : 00000000  r2 : 00000000  r1 : 5f729d30  r0 : 00000019
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 18c5387d  Table: 1a61804a  DAC: 00000015
Process insmod (pid: 589, stack limit = 0x5f728240)
Stack: (0x5f729da8 to 0x5f72a000)
9da0:                   404830dc 401d04e4 00000000 0000000a ffffffff ffffffff
9dc0: 5f46da34 20000093 00000280 00100001 00100002 5f729e28 40578343 00000015
9de0: 5f4ccb00 3f00003c 00000000 00000001 5f729f58 401d24e8 000000d0 5f729e28
9e00: 5f729e28 3f00085c 3f000868 5f4ccb00 40663598 40663598 5f5d9e80 3f00003c
9e20: 00000000 00000001 5f729f58 40008878 00000000 00000001 00000001 40088184
9e40: 40663504 5ffc5380 5fbd8000 00000000 5f5d9e80 00000000 0000001c 00000000
9e60: 5ffc5380 40089570 5ffc5380 00000000 00000000 5f4ccb00 00000002 00000001
9e80: 3f00085c 3f000868 00000001 5f5d9e80 3f0008a4 0000001c 00000001 4006f988
9ea0: 3f000868 00007fff 4006d404 60803000 60800000 4006d058 00000000 00000000
9ec0: 40660490 3f000994 4046c158 608c826c 5f729eec 000da53f 000000d2 405ce9b4
9ee0: 5f4db940 ffffffff 00000010 000002d2 000e3aac 00000000 00000000 00000000
9f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9f20: 00000000 00000000 00000000 00000000 000000d2 000e6040 00001a99 000da53f
9f40: 00000080 4000e1a4 5f728000 00000000 000e3aac 4006fd10 608c7000 00001a99
9f60: 608c7efc 608c7e07 608c88e4 000009a4 00000aa4 00000000 00000000 00000000
9f80: 00000016 00000017 0000000e 0000000c 0000000a 00000000 000e33fc 3e9a0e84
9fa0: 00000069 4000e020 000e33fc 3e9a0e84 000e6040 00001a99 000da53f 00000000
9fc0: 000e33fc 3e9a0e84 00000069 00000080 3e9a0e88 00000000 3e9a0e88 000e3aac
9fe0: 00000001 3e9a0b3c 0001dca0 36e3abd4 60000010 000e6040 00000000 00000000
[<3f0000ec>] (axi_dma_init [hello]) from [<40008878>] (do_one_initcall+0xf8/0x190)
[<40008878>] (do_one_initcall) from [<4006f988>] (load_module+0x18ac/0x1b74)
[<4006f988>] (load_module) from [<4006fd10>] (SyS_init_module+0xc0/0xd8)
[<4006fd10>] (SyS_init_module) from [<4000e020>] (ret_fast_syscall+0x0/0x30)
Code: e3540000 159f03a0 059f03a0 eb517fa2 (e5953000)
---[ end trace 87a90eec3bb4db06 ]---
Segmentation fault
The associated files are listed below.
Observer 32100004
Re: Linux DMA tx channel not found
Well, I forgot to config tx chan in HW when designing.
Observer 32100004
I learn the example from here. It gives a way to use DMA with only rx chan though problem still remains. The loopback example has been tested successfully with other examples. I do not know whether error occurs in hardware or any other places. Can anyone help me solve the problems I've met with ? Thanks for all helps.
Observer 32100004
