muh_ali
Linux Micrel Ethernet Not Working Properly
We have a custom Zynq board with Micrel KSZ9031RNX gigabit ethernet phy. It boots linux with Linaro rootfs. Our reference project is "http://www.zedboard.org/sites/default/files/design/Ubuntu_on_Zedboard_Tutorial_v14.4_02.pdf" and "http://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq". Ethernet generally works but sometimes it does not working. If we wait without doing anything about 10 minutes, we get following error messages and linux crashes. Besides that, ethernet works sometimes 100Mbit mode.
Linux kernel source : https://github.com/analogdevicesinc/linux  tag: xcomm_zynq-2013-04-19 (with micrel driver update)
Device tree : zynq-zed-adv7511.dts in the linux kernel source with some modifications
Are there anyone in the forum who has idea about the problem?
Ali
Error message:
xemacps e000b000.eth: transmit timeout 3000 ms, r.
[ INFO: inconsistent lock state ]
3.6.0-g54e27e6-dirty #3 Tainted: G        W
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/1/0 [HC0[0]:SC1[1]:HE0:SE0] takes:
 (cma_mutex){+.?...}, at: [<c01cd924>] dma_release_from_contiguous+0x74/0xb4
{SOFTIRQ-ON-W} state was registered at:
  [<c0059bd0>] __lock_acquire+0x7d8/0x1b80
  [<c005b3d8>] lock_acquire+0x60/0x74
  [<c0363638>] mutex_lock_nested+0x44/0x398
  [<c01cd810>] dma_alloc_from_contiguous+0x64/0x104
  [<c00165fc>] __alloc_from_contiguous+0x28/0x58
  [<c04dad74>] atomic_pool_init+0x60/0x110
  [<c0008544>] do_one_initcall+0x90/0x164
  [<c04d68dc>] kernel_init+0xf8/0x1b8
  [<c000e308>] kernel_thread_exit+0x0/0x8
irq event stamp: 1349073
hardirqs last  enabled at (1349072): [<c000d3e8>] __irq_svc+0x68/0x78
hardirqs last disabled at (1349073): [<c03655fc>] _raw_spin_lock_irqsave+0x18/04
softirqs last  enabled at (1349020): [<c00257e0>] irq_enter+0x4c/0x6c
softirqs last disabled at (1349021): [<c0025858>] irq_exit+0x58/0x7c
other info that might help us debug this:
 Possible unsafe locking scenario:
       CPU0
  lock(cma_mutex);
  <Interrupt>
    lock(cma_mutex);
 *** DEADLOCK ***
3 locks held by swapper/1/0:
 #0:  (&dev->watchdog_timer){+.-...}, at: [<c002b140>] run_timer_softirq+0xfc/04
 #1:  (&(&dev->tx_global_lock)->rlock){+.-...}, at: [<c02e4150>] dev_watchdog+0c
 #2:  (&(&lp->lock)->rlock){..-...}, at: [<c020abdc>] xemacps_tx_timeout+0x68/08
stack backtrace:
[<c001331c>] (unwind_backtrace+0x0/0xe0) from [<c03604a0>] (print_usage_bug+0x2)
[<c03604a0>] (print_usage_bug+0x258/0x2c0) from [<c0059104>] (mark_lock+0x364/0)
[<c0059104>] (mark_lock+0x364/0x658) from [<c0059b4c>] (__lock_acquire+0x754/0x)
[<c0059b4c>] (__lock_acquire+0x754/0x1b80) from [<c005b3d8>] (lock_acquire+0x60)
[<c005b3d8>] (lock_acquire+0x60/0x74) from [<c0363638>] (mutex_lock_nested+0x44)
[<c0363638>] (mutex_lock_nested+0x44/0x398) from [<c01cd924>] (dma_release_from)
[<c01cd924>] (dma_release_from_contiguous+0x74/0xb4) from [<c020a738>] (xemacps)
[<c020a738>] (xemacps_descriptor_free+0x198/0x1ec) from [<c020ac24>] (xemacps_t)
[<c020ac24>] (xemacps_tx_timeout+0xb0/0x168) from [<c02e42ac>] (dev_watchdog+0x)
[<c02e42ac>] (dev_watchdog+0x174/0x26c) from [<c002b1d8>] (run_timer_softirq+0x)
[<c002b1d8>] (run_timer_softirq+0x194/0x264) from [<c0025280>] (__do_softirq+0x)
[<c0025280>] (__do_softirq+0xcc/0x19c) from [<c0025858>] (irq_exit+0x58/0x7c)
[<c0025858>] (irq_exit+0x58/0x7c) from [<c000e0c0>] (handle_IRQ+0x7c/0xb8)
[<c000e0c0>] (handle_IRQ+0x7c/0xb8) from [<c0008460>] (gic_handle_irq+0x38/0x5c)
[<c0008460>] (gic_handle_irq+0x38/0x5c) from [<c000d3c4>] (__irq_svc+0x44/0x78)
Exception stack(0xdcc77fa0 to 0xdcc77fe8)
7fa0: dcc76000 00149598 dcc77fd8 dcc6e0c0 1cc6006a 00000015 10c0387d c054ec94
7fc0: 0000406a 413fc090 00000000 00000000 00000000 dcc77fe8 dcc76018 c000e36c
7fe0: 20000013 ffffffff
[<c000d3c4>] (__irq_svc+0x44/0x78) from [<c000e36c>] (default_idle+0x28/0x30)
[<c000e36c>] (default_idle+0x28/0x30) from [<c000e558>] (cpu_idle+0x8c/0xe4)
[<c000e558>] (cpu_idle+0x8c/0xe4) from [<0035c414>] (0x35c414)
------------[ cut here ]------------
WARNING: at arch/arm/mm/dma-mapping.c:743 __arm_dma_free.isra.10+0xfc/0x178()
Modules linked in:
[<c001331c>] (unwind_backtrace+0x0/0xe0) from [<c001de68>] (warn_slowpath_commo)
[<c001de68>] (warn_slowpath_common+0x4c/0x64) from [<c001de98>] (warn_slowpath_)
[<c001de98>] (warn_slowpath_null+0x18/0x1c) from [<c0016dac>] (__arm_dma_free.i)
[<c0016dac>] (__arm_dma_free.isra.10+0xfc/0x178) from [<c020a780>] (xemacps_des)
[<c020a780>] (xemacps_descriptor_free+0x1e0/0x1ec) from [<c020ac24>] (xemacps_t)
---[ end trace 062cd48f59c2670b ]---
WARNING: at kernel/smp.c:461 smp_call_function_many+0x98/0x25c()
Modules linked in:
[<c001de98>] (warn_slowpath_null+0x18/0x1c) from [<c0060b58>] (smp_call_functio)
[<c0060b58>] (smp_call_function_many+0x98/0x25c) from [<c0060d4c>] (on_each_cpu)
[<c0060d4c>] (on_each_cpu_mask+0x30/0x98) from [<c00a9840>] (set_migratetype_is)
[<c00a9840>] (set_migratetype_isolate+0xb0/0xbc) from [<c00a9964>] (start_isola)
[<c00a9964>] (start_isolate_page_range+0x48/0x98) from [<c0082bc4>] (alloc_cont)
[<c0082bc4>] (alloc_contig_range+0x40/0x360) from [<c01cd850>] (dma_alloc_from_)
[<c01cd850>] (dma_alloc_from_contiguous+0xa4/0x104) from [<c00165fc>] (__alloc_)
[<c00165fc>] (__alloc_from_contiguous+0x28/0x58) from [<c0017030>] (__dma_alloc)
[<c0017030>] (__dma_alloc.isra.13+0x1f0/0x264) from [<c00171b4>] (arm_dma_alloc)
[<c00171b4>] (arm_dma_alloc+0x80/0x8c) from [<c020a814>] (xemacps_descriptor_in)
[<c020a814>] (xemacps_descriptor_init+0x88/0x288) from [<c020ac3c>] (xemacps_tx)
[<c020ac3c>] (xemacps_tx_timeout+0xc8/0x168) from [<c02e42ac>] (dev_watchdog+0x)
---[ end trace 062cd48f59c2670c ]---
WARNING: at kernel/smp.c:322 smp_call_function_single+0xa8/0x1d4()
Modules linked in:
[<c001de98>] (warn_slowpath_null+0x18/0x1c) from [<c0060994>] (smp_call_functio)
[<c0060994>] (smp_call_function_single+0xa8/0x1d4) from [<c0060d4c>] (on_each_c)
---[ end trace 062cd48f59c2670d ]---
BUG: scheduling while atomic: swapper/1/0/0x40000105
INFO: lockdep is turned off.
Modules linked in:
[<c001331c>] (unwind_backtrace+0x0/0xe0) from [<c035f9e0>] (__schedule_bug+0x60)
[<c035f9e0>] (__schedule_bug+0x60/0x74) from [<c0364484>] (__schedule+0x68/0x65)
[<c0364484>] (__schedule+0x68/0x658) from [<c0044cac>] (__cond_resched+0x24/0x3)
[<c0044cac>] (__cond_resched+0x24/0x34) from [<c0364b00>] (_cond_resched+0x34/0)
[<c0364b00>] (_cond_resched+0x34/0x44) from [<c0092660>] (isolate_migratepages_)
[<c0092660>] (isolate_migratepages_range+0xb8/0x3f4) from [<c0082c74>] (alloc_c)
[<c0082c74>] (alloc_contig_range+0xf0/0x360) from [<c01cd850>] (dma_alloc_from_)
BUG: spinlock lockup suspected on CPU#1, rs:main Q:Reg/922
 lock: 0xdcc925c4, .magic: dead4ead, .owner: swapper/1/0, .owner_cpu: 1
[<c001331c>] (unwind_backtrace+0x0/0xe0) from [<c0171fb0>] (do_raw_spin_lock+0x)
[<c0171fb0>] (do_raw_spin_lock+0x124/0x148) from [<c036563c>] (_raw_spin_lock_i)
[<c036563c>] (_raw_spin_lock_irqsave+0x58/0x64) from [<c020b0a4>] (xemacps_gen_)
[<c020b0a4>] (xemacps_gen_purpose_timerhandler+0x18/0x84) from [<c002b1d8>] (ru)
[<c0025858>] (irq_exit+0x58/0x7c) from [<c0012684>] (handle_IPI+0x6c/0xb4)
[<c0012684>] (handle_IPI+0x6c/0xb4) from [<c000847c>] (gic_handle_irq+0x54/0x5c)
[<c000847c>] (gic_handle_irq+0x54/0x5c) from [<c000d3c4>] (__irq_svc+0x44/0x78)
Exception stack(0xdc5c3c58 to 0xdc5c3ca0)
3c40:                                                       00000000 c0b0f440
3c60: 0000087d dc926a4c c0b0f440 dc926a4c 000000ab 00000000 000000ab 00000080
3c80: dc926a4c dc5c3d60 00000000 dc5c3ca0 c007c308 c007c338 60000013 ffffffff
[<c000d3c4>] (__irq_svc+0x44/0x78) from [<c007c338>] (find_lock_page+0x60/0x68)
[<c007c338>] (find_lock_page+0x60/0x68) from [<c007c840>] (grab_cache_page_writ)
[<c007c840>] (grab_cache_page_write_begin+0x38/0xb4) from [<c0107a1c>] (ext4_da)
[<c0107a1c>] (ext4_da_write_begin+0xb0/0x178) from [<c007b6b0>] (generic_file_b)
[<c007b6b0>] (generic_file_buffered_write+0xc8/0x24c) from [<c007d3d4>] (__gene)
[<c007d3d4>] (__generic_file_aio_write+0x358/0x398) from [<c007d484>] (generic_)
[<c007d484>] (generic_file_aio_write+0x70/0xd8) from [<c01022b8>] (ext4_file_wr)
[<c01022b8>] (ext4_file_write+0x528/0x568) from [<c00ab3ac>] (do_sync_write+0x8)
[<c00ab3ac>] (do_sync_write+0x84/0xc4) from [<c00abbf4>] (vfs_write+0xb0/0x128)
[<c00abbf4>] (vfs_write+0xb0/0x128) from [<c00abe34>] (sys_write+0x3c/0x68)
[<c00abe34>] (sys_write+0x3c/0x68) from [<c000d800>] (ret_fast_syscall+0x0/0x3c)
INFO: rcu_preempt detected stalls on CPUs/tasks: { 1} (detected by 0, t=6502 ji)
[<c001331c>] (unwind_backtrace+0x0/0xe0) from [<c006f050>] (rcu_check_callbacks)
[<c006f050>] (rcu_check_callbacks+0x354/0x500) from [<c002b918>] (update_proces)
[<c002b918>] (update_process_times+0x38/0x68) from [<c00562f4>] (tick_sched_tim)
[<c00562f4>] (tick_sched_timer+0x198/0x1e0) from [<c003f7d8>] (__run_hrtimer.is)
[<c003f7d8>] (__run_hrtimer.isra.18+0x50/0xc8) from [<c003fe54>] (hrtimer_inter)
[<c003fe54>] (hrtimer_interrupt+0x11c/0x280) from [<c0012cf8>] (twd_handler+0x2)
[<c0012cf8>] (twd_handler+0x2c/0x40) from [<c006a680>] (handle_percpu_devid_irq)
[<c006a680>] (handle_percpu_devid_irq+0x80/0xa0) from [<c00673e8>] (generic_han)
[<c00673e8>] (generic_handle_irq+0x20/0x30) from [<c000e0bc>] (handle_IRQ+0x78/)
[<c000e0bc>] (handle_IRQ+0x78/0xb8) from [<c0008460>] (gic_handle_irq+0x38/0x5c)
[<c0008460>] (gic_handle_irq+0x38/0x5c) from [<c000d59c>] (__irq_usr+0x3c/0x60)
Exception stack(0xd4d05fb0 to 0xd4d05ff8)
5fa0:                                     b6a27684 00000008 00000004 000003fd
5fc0: b4d01190 b4d02848 b6a27a94 b4d03678 00000000 b4d01140 b4d02840 00000004
5fe0: b6a7706c b56fe7c0 b69b553b b69ccad0 800f0030 ffffffff
sorenb
Please update your kernel. The xemacps driver was quite heavily worked on. I think the locking issues are fixed by now.
sorenb
muh_ali
sorenb,
You are right. We updated kernel from "https://github.com/Xilinx/linux-xlnx" repository and tag "xilinx-v14.6". And now ethernet always works, at least for 75 tests. Thanks.
Last issue is speed changing. It works generally at 1Gbit but sometimes at 100Mbit. I think, it is hard to say something about this problem because it can be even a hardware issue. Would you suggest anything about the issue?
Ali
muh_ali
Speed issue was related to our test environment. In our setup: board is connected to gigabit switch and gigabit switch is connected to 100Mbit router. Somehow ethernet gets different speeds in this setup.
We tested ethernet connection with cross cable on a pc. And it worked as expected.
Ali
sorenb
aweseome. Thanks for letting us know.
ierkiaga
We have a custom board with Zynq 7030 and Micrel KSZ9031RNX Phy controller.
I updated linux sources to the last version (3.9) and I configured it enabling "CONFIG_MICREL_PHY=y" option. When linux boot ups, link enabled message appears, but connection si not workin properly (pings to host PC or from host PC).
Link Leds are working in ethernet connector.
Console output:
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
xemacps e000b000.eth: Set clk to 124999998 Hz
xemacps e000b000.eth: link up (1000/FULL)
Devicetree:
eth@e000b000 {
141       compatible = "xlnx,ps7-ethernet-1.00.a";
142       reg = <0xe000b000 0x1000>;
143       interrupts = <0x0 0x16 0x4>;
144       interrupt-parent = <0x1>;
145       phy-handle = <0x3>;
146       phy-mode = "rgmii-id";
147       xlnx,ptp-enet-clock = <0x69f6bc7>;
148       xlnx,slcr-div0-1000Mbps = <0x8>;
149       xlnx,slcr-div0-100Mbps = <0x8>;
150       xlnx,slcr-div0-10Mbps = <0x8>;
151       xlnx,slcr-div1-1000Mbps = <0x1>;
152       xlnx,slcr-div1-100Mbps = <0x5>;
153       xlnx,slcr-div1-10Mbps = <0x32>;
154       #address-cells = <0x1>;
155       #size-cells = <0x0>;
156
157       mdio {
158         #address-cells = <0x1>;
159         #size-cells = <0x0>;
160
161         phy@7 {
162           compatible = "marvell,88e1116r";
163           device_type = "ethernet-phy";
164           reg = <0x7>;
165           linux,phandle = <0x3>;
166           phandle = <0x3>;
167         };
168       };
169     };
Anyone knows if I forget to configure something or where is the source of failures??
ierkiaga
Looking properly the design I get into account that my phy addr is 011, so I change the devicetree:
          mdio {
160
161         phy0: phy@3 {
162           compatible = "micrel,ksz9031";
164           reg = <0x3>;
165         };
166       };
167     };
 However ethernet is not working properly. I enabled debug console and I got following info about ethernet subsystem:
xemacps e000b000.eth: open
xemacps e000b000.eth: RX ring 2048 bytes at 0x2e841000 mapped ee841000
xemacps e000b000.eth: TX ring 2048 bytes at 0x2e842000 mapped ee842000
xemacps e000b000.eth: lp->tx_bd ee842000 lp->tx_bd_dma 2e842000 lp->tx_skb ee031000
xemacps e000b000.eth: lp->rx_bd ee841000 lp->rx_bd_dma 2e841000 lp->rx_skb ee28e000
xemacps e000b000.eth: MAC 0x00350a00, 0x00002201, 00:0a:35:00:01:22
xemacps e000b000.eth: GEM: phydev ee17c400, phydev->phy_id 0x0, phydev->addr 0x3
xemacps e000b000.eth: phy_addr 0x3, phy_id 0x00000000
xemacps e000b000.eth: attach [Generic PHY] phy driver
 It seems that phy_id is wrong and generic driver is taken instead of Micrel's one
brmy
hi ,I just want to know, do you solve your problem ?how did you do it?
ierkiaga
Hi everybody,
After some private messages asking for our Ethernet solution with Micrel's (KSZ9031), I'm going to post our schematic and the devicetree definition (14.7 release). It should help you in your designs!
If someone has any question about that please feel free to contact with me.
ps7-ethernet@e000b000 {
			clock-names = "ref_clk", "aper_clk";
			clocks = <0x3 0xd 0x3 0x1e>;
			interrupt-parent = <0x2>;
			local-mac-address = [00 0a 35 00 00 00];
			phy-handle = <0x4>;
			xlnx,enet-reset = "MIO 47";
			xlnx,eth-mode = <0x1>;
			xlnx,has-mdio = <0x1>;
			xlnx,ptp-enet-clock = <0x69f6bcb>;
			mdio {
				phy@3 {
					reg = <0x3>;
					linux,phandle = <0x4>;
					phandle = <0x4>;
ghvr1521
We are also facing same problme. PHY is getting detected. But PING is not happening. How did you solve your problem??
