Visitor jlynnc
Linux on CPU0 and bare metal on CPU1
Platfom information:
vivado 2016.2
sdk 2016.2
petalinux 2016.2
Board: a customized zc7045 board
Issues:
I need to run the Linux on cpu0 and bare metal on cpu1, refer to the XAPP1079, I created a new project for cpu1, the code is attached. But I didn't import the repo from the doc. The OS version is 5.5.
The memory map:
0x0-0x10000000 256MB for linux
0x10000000-0x20000000 256MB for bare metal
I just added the macro -g -DUSE_AMP
The bif file as following :
//arch = zynq; split = false; format = BIN
the_ROM_image:
	[bootloader]D:\zynq\project\prj_fh7045_v1\prj_fh7045_v1.sdk\fsbl_test\Debug\fsbl_test.elf
	D:\zynq\project\prj_fh7045_v1\prj_fh7045_v1.sdk\design_1_wrapper_hw_platform_0\design_1_wrapper.bit
	C:\Users\Julian\Desktop\u-boot.elf
	D:\zynq\project\prj_fh7045_v1\prj_fh7045_v1.sdk\cpu1_app\Debug\cpu1_app.elf
	[load = 0xFFFFFFF0]D:\zynq\project\prj_fh7045_v1\prj_fh7045_v1.sdk\cpu1_app\bootimage\cpu1_bootvec.bin
If I used this bif to gen the boot.bin, the u-boot can not start. The error is:
INVALID_LOAD_ADDRESS_FAIL
I found this error message in the file image_mover.c:
means the partitionloadaddr(0xFFFFFFF0) is greater than DDR_END_ADDR(0x3fffffff)
How to solve this problem?
Then I deleted the last line of bif file, remove the cpu1_bootvec.bin, the u-boot is ok, but the cpu1 can not run. Using following command to run:
root@zynq_test:/mnt# ./rwmem.elf 0xfffffff0
0x00000000fffffff0 = 0xffffff2c
root@zynq_test:/mnt# ./rwmem.elf 0xfffffff0 0x10000000
0x00000000fffffff0 = 0x10000000
root@zynq_test:/mnt# ./rwmem.elf 0x10000000
0x0000000010000000 = 0xedfe0dd0
I also watched the addr 0x10000000, the contents are not the content of cpu1_app.elf.
If I created a app for cpu0, using the same memory map and cpu1 app, the 2 bare metal AMP system runs well.
BTW:
Refer to the UG585 doc, the cpu0 need to send SEV command to CPU1, but I can not find how to send this event on linux
Visitor jlynnc
Re: Linux on CPU0 and bare metal on CPU1
Sorry, I forgot the attachment
Visitor jpoyhia
Try swapping the bare metal app and Linux in your memory map. I think the bare metal needs to be at address 0x0 when using Linux. Take a look at this.
