MIO allocation in RFSOC
I have 2 identical customized boards based on RFSOC.
In the first board, the allocation of MIO lines is different from the second one.
The MIO allocation is defined in VIVADO.
I'm using Petalinux (2018.3) to create FSBL, PMU, BL31, U-boot, Linux kernel.
Will the FSBL, PMU, BL31, U-boot be the same for both boards ?
Or only the device tree will be different ?
Thank you,
Zvika
