gma-87
MJPEG on Zedboard
hello,
after install Xillinux on ZedBoard, i want to run MJPEG decoder on this paltform
1- i can't found a source code of MJPEG ( serial and paralell version ), just i found MJPEG Streamer ( i try to run it on Zedboard, because i saw other user, have succefully this example )
2- have any one, idea or tried to run one thread of MJPEG ( parallel version ), using the PS and PL ( FPGA )
in other way, there is any dicumentation abut affecting thread to processor ( ARM in this case ), or to PL ?
thank you  for your help
My blog : www.xilinx-video.blogspot.com
Tags (5)
rfs613
I've used the jpgsrc-6b package on Zynq (newer version here: http://www.ijg.org/). It is not the fastest, but the code is portable to x86, arm, powerpc, etc.
I have not used MJPEG, but it looks like ffmpeg might be a good starting point.
Of course there are probably many much more highly optimized choices, i'm not really familiar with them. After all, most mobile phones have ARM processors in them these days.
gma-87
update :
i readed all this discussion, really it's so nice to found people like you, answer on question, and try to foudn solution for people like us :)
i have a project : run MJPEG on ZedBoard ( i use Xillinux ( based on Ubuntu 12.04)  as an OS with SMP )
i have the code source of MJPEg in 2 version ( serial and parallel )
1- have idea how, can i run or affect the .c fite to run just on the first CPU ( no problem CPU0 or CPU1), just i need to run this application on single CPU
2- the second version of MJPEG is parrelel, have you any idea, or previous example, where can we affect or run one thread on the PL , ( i didn't found any documentation about this )
also, i readed some other post similare to my question, one of its on  this link
the following picture, show activities of the PS  ( 2 ARM )
thank you
Tags (5)
rfs613
1- The keyword you are looking for is "Processor Affinity". You can use the command "taskset" to control which CPU a task runs on. http://linuxcommand.org/man_pages/taskset1.html
2- This is non-trivial, you cannot just "convert" .c code to FPGA blocks. However you can likely find some PL logic that can be used to accelerate some portion of your encoding/decoding.
gma-87
hello,
thank you for your response
1- for the affinity, i found this post on forum, they talk about FreeOS, in my case i have Xillinux ( ubuntu), it's possible de make this manipulation on OS like ubuntu ?
 2- " convert", i don't think it's convert, i watcha demo from Avnet on ZedBoard, they try the OpenCv on Zynq, and they make a migration of some fonctionnality to PL ( check the follow video )
thank you
rfs613
1- the "settask" command is for Linux (which includes Ubuntu). As mentioned in the other forum post, generally the Linux scheduler is better than manually forcing the affinity. This is assuming you run linux on both CPUs. It is also possible run FreeRTOS (or something else) on one core -- that's a completely different thing though.
2- I'm not too familiar with OpenCV, I do know it can be used to offload some calculations, but it it's not "magic" solution to performance problems.
gma-87
hello,
thank you for your time to response,
no problem for OpenCv, just i try to run it on ZedBoard,
for the  use of a single processor, it's a recommandation of my responsible, i also, use Xillinux as an OS, after this step, i try th afinity method
but i still can't found the source code of MJPEG or JPEG compatible for ARM architutre ( i found this but it's only for x86, i meet a problem in build, because it's for x86 )
rfs613
gma-87
hello
thank you , it's work, i get the source code of the last version  of jpeg ( encoder and decoder )
i run it on ZYNQ and it's work :)
i begin to write a script to run djpeg on one CPU , usign the affinity proce
for the MJPEG, i think it's the same code, juste in the place of picture input, i will use a video file, ( because jpeg compatible with mpeg extenssion video file, or i will try to add some line code to accept video format as an input
BUT, i retur to my board, ( i delete the folder whitch cantain the extrct files ), i try tar -xvf jpegsrc.v9a.tar.gz ( again ), next i try make, make install, ./configure , but no positive result :(  , i can't found a reason , ( in the begin, it's work fine, with djpeg and cjpeg executable file, even i try some example ,and it's work
please, can you check this problem
thank you
rfs613
Try setting the date/time of your board. It is likely in Jan 1st 1970 by default , because there is no real-time clock.
gma-87
hello
gma-87
hello,
i try to use the taskset, but it's so dificult, because i can't get the PID of a task whitch isn't created yet :( , so i try other method, i just disactivate the second CPU :)
check this method ( so simple )
rfs613
The PID is not necessary to use taskset. Just prefix your command like this:
taskset mask -- yourcommand args
gma-87
hello,
i tried to run ,
taskset -p 03 ./djpeg outfile sourcefile
but i get error :
taskset : failed to parse pid : ' sourcefile ' ,
i think taskset, can't support an execution command
thank you
sorenb
If you tell it to work with a PID, it requires a PID... Leave out the '-p'.
rfs613
Try like so:
taskset 0x03 -- ./djpeg outfile sourcefile
Note there are spaces on either side of the double-dash.
gma-87
hello
same thing, i try your suggestion
gma-87
hello,
any suggestion, about taskset , please can you check my last screenshut
i can't found the correct syntax of taskset, ( i tried taskset -help ) , but i can't found how can i runa command on cpu1
thank you
rfs613
Seems your version does not like the double dash. Try it like this (as suggested by sorenb):
taskset 0x03 ./djpeg etc....
rfs613
Also, the value 0x03 selects both CPU #0 and #1.
It is a bit mask, each bit corresponds to one CPU.
So to run only on cpu1, you use 0x02.
gma-87
hello,
it's work, thank you :)
taskset 0x02 ./djpeg -outfile ./path/outputfile ./path/inputfile  ( this command work on terminal )  :)
but when i tried to use this command into script ( script.sh ) , i tried to run this command inti for ( loop ), for 50 loop ( as an example ) , i discovred that both of CPU, execute together this traitement, whitch mean ( taskset don't relly affect or force the traitment on signle processor, check the folowing picture (, look to CPU1 and CPU2  activities ), even when i use a simple commad without script ( i saw that 2 CPU run in the same time), bu to make sure if really those CPU work together , i use a script to run 50  repeated command
the JPEG decoder still 20 seconds to run the decode of 50 image in JPG format
thank you
Tags (3)
rfs613
I wonder if some other task (file manager, thumbnail generator, etc) may be responsible for the second CPU becoming active. In other words, 'djpeg' process may be locked correctly to cpu1, but operating system is also running other processing on cpu2.
To test, you could run djpeg, but output to /dev/null, so that it only decodes, rather than generating any files.
It is also strange that the execution time of your program varies so much (12s to 38sec). For the same series of images, processing time should be virtually identical each time.
farrionet
Excuse me guys,  this thread seems to be MJPEG related right? I also have a related question. Recently, I got a video of MJPEG from someone else and it was from a cam i think. I could not open it with our common players like Windows Media Player and VLC. Then, I find a converter in the article "http://www.videoconverterfactory.com/tips/mjpeg-converter.html". But here are the questions. I want to convert it to MP4, but I do not know how I can set the parameters. There are bit rate, resolution and frame rate. I want to know whether the higher bit rate and resolution I set, the better output it will be? What is the difference between bit  rate and resolution? I cannot figure it out by googling. Another question is should I choose MPEG4 or H264 as the output format, which one is better?
