MPSOC+VCU+UBUNTU
Hi ! I try to set up : Zynq UltraScale + MPSoC Ubuntu + VCU + Gstreamer - Building and Running "Ubuntu Desktop" https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/148668419/Zynq+UltraScale+MPSoC+Ubuntu+VCU+Gstreamer+-+Building+and+Running+Ubuntu+Desktop+from+Sources I work on ZCU106 (the same board), I followed the instruction to boot with SD card by using HDF and BSP files provided in the zip files. I successfully built the petalinux project and generated binary files.
I try to boot on the board (SD card), I can see the FSBL and u-boot running , and then start the kernel.
But after some run, the system hang just like the picture and I don't know where
Re: MPSOC+VCU+UBUNTU
Hi @125215153
Can you try whether ready to test images provided as part of zip file, works at your end?
When I use img files provided by xilinx wiki , result in zcu106 ddr revisions , it stuck in fsbl
