Migrating from PetaLinux 2017.4 to 2018.1 - extra hoops to jump through
I wanted to document my migration from PetaLinux 2017.4 to 2018.1, in case it saves anyone else some time. For background, I have a fully scripted build from Vivado through SDK to PetaLinux, targeting a MicroZed based board (7Z020).
Aside from renaming device-tree-generation_%.bbappend to device-tree.bbappend as mentioned in the Migration appendix in UG1144, I found I was also having trouble with my FSBL not getting generated and U-Boot failing to build.
FSBL Changes
After updating, I found that my FSBL wasn't being generated as part of petalinux-build. I keep {PL_ROOT}/project-spec/meta-user/conf/petalinuxbsp.conf in source control. In 2017.4, this was essentially a blank file by default. In 2018.1, this now includes the following:
#User Configuration
#OE_TERMINAL = "tmux"
# Add EXTRA_IMAGEDEPENDS default components
EXTRA_IMAGEDEPENDS_append_zynqmp = " virtual/fsbl virtual/pmu-firmware arm-trusted-firmware"
EXTRA_IMAGEDEPENDS_append_zynq = " virtual/fsbl"
EXTRA_IMAGEDEPENDS_append_microblaze = " virtual/fsboot virtual/elfrealloc"
#Remove all qemu contents
IMAGE_CLASSES_remove = "image-types-xilinx-qemu qemuboot-xilinx"
IMAGE_FSTYPES_remove = "wic.qemu-sd"
EXTRA_IMAGEDEPENDS_remove = "qemu-helper-native virtual/boot-bin"
Without the EXTRA_IMAGEDEPENDS_append_*, the FSBL does not get built by default. This change in FSBL generation behavior should be covered in the Migration information.
U-Boot Changes
U-Boot seems to have undergone a similar change in default behavior. I keep {PL_ROOT}/project-spec/meta-user/recipes-bsp/u-boot/* under source control. In 2017.4, the default platform-top.h was:
#include <configs/platform-auto.h>
#define CONFIG_SYS_BOOTM_LEN 0xF000000
/*Required for uartless designs */
#ifndef CONFIG_BAUDRATE
#define CONFIG_BAUDRATE 115200
#ifdef CONFIG_DEBUG_UART
#undef CONFIG_DEBUG_UART
#endif
#endif
With this config, u-boot fails to build during petalinux-build. The new default platform-top.h in 2018.1 is:
#define DFU_ALT_INFO_RAM \
                "dfu_ram_info=" \
        "setenv dfu_alt_info " \
        "image.ub ram $netstart 0x1e00000\0" \
        "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \
        "thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
#define DFU_ALT_INFO_MMC \
        "dfu_mmc_info=" \
        "set dfu_alt_info " \
        "${kernel_image} fat 0 1\\\\;" \
        "dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" \
        "thor_mmc=run dfu_mmc_info && thordown 0 mmc 0\0"
#endif
#endif
/*Define CONFIG_ZYNQ_EEPROM here and its necessaries in u-boot menuconfig if you had EEPROM memory. */
#ifdef CONFIG_ZYNQ_EEPROM
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN         1
#define CONFIG_SYS_I2C_EEPROM_ADDR             0x54
#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS      4
#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS  5
#define CONFIG_SYS_EEPROM_SIZE                 1024 /* Bytes */
#define CONFIG_SYS_I2C_MUX_ADDR                0x74
#define CONFIG_SYS_I2C_MUX_EEPROM_SEL          0x4
#endif
Again, this change isn't mentioned in the Migration index.
U-Boot Bug?
Upon building my project and trying to boot from an SD card, U-Boot was failing with the error Unknown command 'booti' - try 'help'. I'm a U-Boot novice, but after a LOT of comparing changes, merging my 2017.4 configs with the 2018.1 defaults (and general shotgun debugging), it seems there may be a bug with setting U-Boot to load the DTB from an SD card.
In {PL_ROOT}/project-spec/configs/config, the default dtb image setting:
CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_BOOTIMAGE_SELECT=y
produces a U-Boot default boot command of:
default_bootcmd=run uenvboot; run cp_kernel2ram && bootm ${netstart}
Instead, if the dtb image setting is configured to load from an SD card:
CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_SD_SELECT=y
then the default boot command changes to:
default_bootcmd=run uenvboot; run cp_kernel2ram && run cp_dtb2ram && booti ${netstart} - ${dtbnetstart}
The problem is the bootm becoming booti. As a workaround, I tried redefining default_bootcmd in a uEnv.txt on my SD card. I can see the variable has updated by running printenv in U-Boot, but the original default still seems to get loaded at startup and the booti error appears. Annoyingly, just doing run default_bootcmd after the initial error results in a normal boot using the default defined in uEnv.txt. I'm guessing there is some kind of env loading order problem. If anyone can let me know why uEnv.txt gets ignored, I would be keen to know!
Instead, my current workaround is to redefine CONFIG_BOOTCOMMAND in platform-top.h by adding the following to the bottom of the file:
/* Due to a bug where having u-boot load dtb from SD card causes the boot
 * command to default to using booti instead of bootm on Zynq, the defult build
 * fails to boot. This boot command override is a temporary workaround.
#ifdef CONFIG_BOOTCOMMAND
#undef CONFIG_BOOTCOMMAND
#define CONFIG_BOOTCOMMAND	"run uenvboot; run cp_kernel2ram && run cp_dtb2ram && bootm ${netstart} - ${dtbnetstart}"
#endif
Is this behavior a bug, or am I doing something wrong? It worked fine in 2017.4
Build Warnings
I'm really not a fan of warnings in default builds. It doesn't give confidence that everything is setup right. I get the same warnings (about virtualization and sysvinit-inittab-2.88dsf-r10.plnx_zynq7) on a default zynq build as in this post. I only bring it up again here in case someone else sees them as part of a migration to 2018.1 and is concerned.
Any input on anything I am doing wrong, or better workarounds, would be greatly appreciated!
Cheers,
Iain
Re: Migrating from PetaLinux 2017.4 to 2018.1 - extra hoops to jump through
Hi Iain,
Just wanted to say thanks for posting this information. I got stuck with the same issues, the BOOT.bin file wasn't being generated, nor was the zynq_fsbl.elf. When I made your changes, specifically the device-tree filename change and the additions to the petalinuxbsp.conf file, the problems were fixed.
Thank you.
Jeff
I'm glad I could help and your thanks is very much appreciated!
The more I work with the xilinx software, the more I think "surely someone else has come across this problem already?!". I'm trying to be good about posting solutions I come up with so that other people don't waste the same time I have.
So when you inevitably solve a problem you haven't seen a post about, please do share!
Cheers,
Iain
I just got the same problem and followed what you instructed and problem was fixed.
Thanks for your share.
I found tha same problem.
In my case  the cause of the problem  was the u-boot environment saved on qspi flash and  produced with previous petalinux compilation.
The solution was to restore the default  u-boot env.
Zynq> env default -a
## Resetting to default environment
