garazigara
Montavista 4.01 and ML507
I`m trying to download  Montavista 4.01   to use it in an embedded design with ML507 board, but I can´t.
Where can I find it? Is there any data sheet explaining how to implement MontaVista in this board?
Garazi
linnj
Sorry I'm no expert here.
You need to go to Montavista for their Linux to my knowledge.
I would look on xilinx.com for an app note about using MontaVista Linux on Xilinx boards.
-- John
garazigara
Thanks for your reply.
I am not an expert in this and I still have another question.
I have made the following steps:
1. Software --> Software Platform Settings:
  • OS:linux_2_6
  • OS and libraries:
                  - Connected peripherals:...
                 - Target directory: C:/ BSP_MONTAVISTA
                  - Linux Distribution: Montavista 4.01
                  - rootfs type: ramdisk
2. Generate Libraries and BSPs
After that several folders are generated: arch(C:\BSP_MONTAVISTA\arch\ppc\kernel, ...), drivers, include...
Is it enough or is it necessary to buy Montavista 4.01 distribution?
A lot of thanks,
Garazi
Message Edited by garazigara on 09-07-2009 02:35 AM
linnj
These files are just the additional files that are needed with the files from MontaVista, so yes you still need a Montavista distribution to my knowledge.
Sorry for the delayed response.
-- John
jothiadithya
You need to buy the distribution from Monta Vista. The Latest version for ML405 or ML507 is 5.0.24
